Which wheels for my mx3
Which wheels
MB motoring
9
60%
Drag DR31
6
40%
Total votes: 15
mitmaks
Post by mitmaks »
I'm liking these wheels and can't decide. Either MB motoring or Drag DR31s
MB motoring 789s
Drag DR31s
MrMazda92
Re: Which wheels for my mx3
Post by MrMazda92 »
I'd go with the 789s, assuming weight isn't a factor.
For me, I'd go with whichever set weighs less. :freak:
Polonius
Post by Polonius »
The 789s look pretty much the same as the cheap wheels around here. Seems like everyone has 'em, and you know they're the cheapest. I think the ones around here are Vision, but I just don't like 7 spokes anymore. :P
1993 MX-3
B6 SOHC
170,000 k
Manual tranny
Demonic1
Post by Demonic1 »
MrMazda92 wrote:I'd go with the 789s, assuming weight isn't a factor.
Which one weighs less. There is your answer.
92 RS BP05
93 GS KLZE
mitmaks
Post by mitmaks »
I would think they weigh the same...
Evo_Spec
Post by Evo_Spec »
mitmaks wrote:I would think they weigh the same...
I chose 17x8 because it was the only size that was the same.
MB Motoring WEAPON 17x8 - 20.0 lbs / 9.1 kg http://www.measurespeed.com/mbmotoring- ... weight.php
Drag DR-31's 17x8 - 21.00 lbs / 9.52 kg http://www.dragwheels.com/product.asp?ID=128
oh, i searched 789 and didn't come up with much and found that they're called the weapons on the actual site http://wheelsbymbmotoring.com/product.php?wheel=Weapon
789 seems to be for the center caps http://www.centercapsdirect.com/BC-789- ... _4590.html
Post by Josh »
Those are heavy as hell.... WTF?! my 17x7 TSW VX1's weigh 22lbs and they are freaking HUGE
IMO I would go with the DR31's, 6/7 spokes are so overplayed these days :)
I would go with a 16x7 or 16x8 if they got them in that size :)
Evo_Spec
Post by Evo_Spec »
Josh wrote:IMO I would go with the DR31's, 6 spokes are so overplayed these days :)
they're 7 spoke =P
Post by Josh »
they're 7 spoke =P
whoops my bad :)
DeadMaker
Post by DeadMaker »
Mb motoring for sure..From beauty size..
Black Mazda Mx3 Rs 1997 B6DE
I don't like universal lug patterns so I would go with the MB for that reason alone... I also think the thicker spokes would look better too.
Return to “Appearance”
