aftermarket rear control arms/trailing arms???
92 mx3 1.8L manual trans.
ok first off, which is which. the rear arms going front to back are.............???
and the rear arms going from center to driver and center to passenger wheel are..............???
both driver and passenger arm that runs front to back are broken completely through around the bushings. Recommendations for aftermarket, or any decent replacement???
Thanks.
Thanks.
Re: aftermarket rear control arms/trailing arms???
The on line manuals have all the information you need to identify which is which. http://www.mx-3.com/manuals/index.php
Recommendations for aftermarket, or any decent replacement of the trailing arms and lateral links???
Nobody makes an MX-3 replacement lateral link or trailing arm. You can get aftermarket parts for the 323/Protege but thelateral links for sure are not exactly the same.
You can still get factory parts, but they're not cheap.
I have the Mazdaspeed rear arm kit, but don't know if they are still available. The Mazdaspeed kit replaced the broken parts you have. I could offer u my stock set of rear arms if you need them. Other than that, there is nothing else out there readily made.
Luc St-Pierre (SRD) did a full solid link setup on his Mx-3. High Knee is 3000kms away, so I can't post a pic, but it's a beautiful setup.
- kulluminati777
i would LOVE some SRD rear suspension stuff!!! Minus the rear tie bar which i have......maybe u or blaznlow could develop some rear arms or lateral links?
![Love2 :love2:](./images/smilies/love2.gif)
Wouldn't happen. Luc didn't even sell his, it was done as a one-off for his car as far as I've seen.
1) Don't have an Mx-3 to work with
2) I don't make the money that I used to and can't front/risk the cash to start such a project
3) Price wise, it wouldn't be cheap. Only a few would probably sell. Would probably be at least $1000, at least.
4) If anything, I'd do it for the Rx-8 if I did.
- bbunkerc397
I thought blaznlow aka (chewy) could do some cool aluminum rear control arms and maybe front lower however this would cost alot of money in aluminum.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
- MrMazda92
We should be looking into a butterfly brace, similar to what Miatas have available. That, with a lightweight cage on the interior, would turn an otherwise stock MX-3 into a go-kart without much else being changed. Add it on to whiteline/MS swaybars, STBs, Poly bushings, and Coilovers... Don't get me started.
Although, you'd never want to drive it on anything but perfect roads.
Chewy?bbunkerc397 wrote:I thought blaznlow aka (chewy) could do some cool aluminum rear control arms and maybe front lower however this would cost alot of money in aluminum.
You'd have to ask him, but I'm not taking any part in that. If Jimmie wants to do it, than it's all up to him.
- bbunkerc397
The way Jimmy says his name on the phone it sounds like chewy and ya probably too much money.
- kulluminati777
only 1000? ill put up 500 now. im sure you could get others to back the cause or you could start something up and see if peeps would pay up front....
- MrMazda92
$1,000 would be way rich for my blood, I imagine others as well unfortunately... I could see $200, but I can think of at least 5 ways I'd rather spend $1,000(Limiting these 5 to my car, even)
If you scan the clubprotege BG chassis suspension and brakes forum there's a thread for tubular rear subframe that one of the rally guys makes. I'm sure that he has a tubular lateral link/trailing link set up as well...but it's vague in my memory.
