I say KLZE, because that's what mine is closest to. I know there isn't anyone else running the same setup with MS. I have been tuning, and screwing around with my AFR map, and was wondering if anyone has fine tuned (especially on a dyno) to find the best AFRs for power, and fuel economy.
 My meter goes to 18:1, and that's what I cruise at for fuel economy. If I go more lean, there is a slight hesitation. For power, I've gone to about 13. Once I get the paid version, I'll datalog, and whatnot.
 I would like to see VE tables of similar setups.
							Specific target AFR for KLZE?
- fowljesse
						- stereoking15
Re: Specific target AFR for KLZE?
Jesse, anything higher than 16= bad, lean out condition can cause excessive heat and possibly burn a valve. At wide open throttle be around 12.5-13 afr is good. Cruising should be 14-15 afr.
						- MrMazda92
Ask, and you shall receive:
http://forums.probetalk.com/showthread.php?t=1701288659
