which axle seal
Posted: July 26th, 2012, 7:26 pm
Rock auto lists 3 car is a 93 sohc 4cult with a manual
MKEN Part # 710223 TIMKEN Part # 710223 Shaft Size: 1.732"; Housing Bore: Shaft Size: 1.732"; Housing Bore: 2.598"; Seal Width: 0.236"; Seal 2.598"; Seal Width: 0.236"; Seal Outside Dia: 2.602"; Seal Lip Material: Outside Dia: 2.602"; Seal Lip Material: Nitrile; Housing Material: Steel; Max Nitrile; Housing Material: Steel; Max Temp: 225°F; Min Temp: -40°F; Seal Temp: 225°F; Min Temp: -40°F; Seal Type: #; Press Fit Type: #; Press Fit MX 3 1.6; Outer MX 3 1.6; Outer
$3.52 $3.52
NATIONAL Part # 710223 NATIONAL Part # 710223 Oil Seal; Nitrile Seal, Shaft Oil Seal; Nitrile Seal, Shaft Size=1.693", Housing Bore=2.205, Size=1.693", Housing Bore=2.205, Outer Diameter=2.209, Width=0.335in Outer Diameter=2.209, Width=0.335in Oute
$3.79 $3.79
TIMKEN Part # 710224 TIMKEN Part # 710224 Shaft Size: 1.496"; Housing Bore: Shaft Size: 1.496"; Housing Bore: 2.441"; Seal Width: 0.236"; Seal 2.441"; Seal Width: 0.236"; Seal Outside Dia: 2.445"; Seal Lip Material: Outside Dia: 2.445"; Seal Lip Material: Nitrile; Housing Material: Steel; Max Nitrile; Housing Material: Steel; Max Temp: 225°F; Min Temp: -40°F; Seal Temp: 225°F; Min Temp: -40°F; Seal Type: 490; Press Fit Type: 490; Press Fit MX 3 1.6; Inner
Thanks for th help
$3.52 $3.52
$3.79 $3.79
Thanks for th help
