i want to paint my car im 18 so no i have never done this before but have been it done once my question is will this paint last a good 3- 5 years if treated right? my car is already primered by the last owner he was ready to paint it and his clutch went out so i got the car put rear and front main seals new starter alternator water pump and battery got her running oh and clutch here is the link to what im looking at buying also how hard would it be to shoot this paint for a first timer? dont have alot of money for Urethane paint
http://www.ebay.com/itm/Candy-Apple-Red ... 221wt_1274
paint question
- mitmaks
Re: paint question
This paint wont last long. However you can put clear coat over it and it will last much longer.
As far as painting it yourself you're better off letting someone else do it, who's experienced, has tools, spray booth and most important painting skill.
- DeadMaker
Re: paint question
To put up a clear coat on it you must sand the surface first with 2000p or you just throw it over the glossy color?
Black Mazda Mx3 Rs 1997 B6DE
- mitmaks
Re: paint question
If you're painting it, you can usually clear coat over top of paint within 1/2 hr to overnight. I usually clear coat within first 30-45mins after painting the car. If you want to put clear coat over entire car and it's already has been previously painted you'd want to wetsand entire car with 800grit. That is only if paint is in good condition, there's no missing/delaminated clear coat, etc.DeadMaker wrote:To put up a clear coat on it you must sand the surface first with 2000p or you just throw it over the glossy color?
If you have delaminated clear coat, the base (actual paint) underneath is already damaged cause it has been exposed to sun. You must sand with 400-600 and put couple coats of paint on the panel and then clear over that.
- DeadMaker
Re: paint question
But when it comes for a singles stage?For example i want to paint my hood with acrylic enamel(can't offer money for polyurethane),can i sand it after two or three days with 800p and then put the clear coat?Rather than put it over the glossy surface..
I am asking these cause i don't have a close room for painting so by sanding it i will have a chance to get rid off any dust from the air.
And btw i don't have a polish machine...
Re: paint question
If you have to paint outside paint first thing in the morning. Bugs are gone and every thing is damp with dew so dust is minimal. Wet the ground down so the paint gun won't stir up dust. If you have close neighbors forget it as the paint mist can drift to them and then it's law suit time.
