Where to buy new calipers?
- Ryan
I'm looking for rear calipers (two sets of rears) and I don't want to pay $200/set.
Where do you guys look? rockauto and ebay are a bust.
- MrMazda92
Re: Where to buy new calipers?
seriously?
I bought a brand new passenger rear on Rock Auto a few months ago. :/
What is the world coming to!?
advance/autozone maybe but unless you work in the store Im pretty sure the calipers are going to run close to $100 a pop. You are buying Mx5 MS calipers right since your replacing both? It would be a good time to upgrade
what about rebuilding some junkyard sets? im sure you have access to a sandblaster, then all the other parts can be had off rockauto for fairly cheap...
i was able to make this out of an old rusty caliper with seized slider pins...
- Ryan
I live in Canada, so no autozone etc. we have Napa, basically, but they overprice normal stuff, nevermind MX-3 parts.
I would do JY parts, but I'm finding it to be impossible with the cores I have. They're all totally effed.
- MrMazda92
I have a passenger rear that functions perfectly... I bought a refurbed one from RockAuto because I couldn't buy a bracket for under $78 ANYWHERE in the timeframe I had... I have until July to return the core to them, I need to find out how much the core was worth to them. I would match it for you, if you're interested.
$200/set? I paid $180 for just one back in the day...
- WhiteFinish
Is it also possible to rebuild the ebrake system ?
- Ryan
calipers are looking to be in the $70/each range.
Does anyone know if 98 escort rear struts fit? my winter car ones are toasty. handling is not a concern, but I can get the pair from a canadian company for $70 shipped/pair. Thats 3rd gen escort. I know 2nd gen is direct bolt... not sure on 3rd. But the ZX-2 S/R is 3rd gen?
I saw some 2005 MX-5 Sports Suspension rear calipers for $60 each on eBay a week ago, dunno if they're still up. Don't bother with Partsource/Canadian Tire or NAPA, it'll be an arm and a leg and maybe a gnad. Rockauto has the Miata rears for $100, with a $37 core included.
Umm, has anyone checked out Rockauto for fronts? $15 for a front caliper, no core???? #4153058 and #4153057.
Rears are $63 no core charge. #14145515 and #14145516
Rockauto seems to be the best bet.
I'm actually doing that with some B&G springs soon. Cept I need some spring insulators to get them assembled. Seems to be right, they appear to be the same as ZX2 struts.Ryan wrote:calipers are looking to be in the $70/each range.
Black 1993 Mazda MX-3 GS - daily driver
Kenwood BT-948HD, MB Quart FX4.100 and ONX1.1000D, Polk MM6501 x4, Polk MM1240
SE interior, MOMO Endurance shift boot, Tomei long shift knob, eBay short shifter
Red 1987 Toyota MR2 - go kart
"If it's crazy you want, it's crazy you get."
- Ryan
I bought and received them already, and they look to be the same geometry.
- Josh
RockAuto is legit, I just bought NGK Laser Iridium's for the C230 the other day, with shipping more than 3 dollars a plug cheaper than anywhere else.
