Oil additives, what do you use?
Posted: April 1st, 2012, 11:16 am
by Sleeper6
So just curious what/if any additives you all use on your motors and what kind of results you see. I use to use lucas religously however we carry a BG product at work that I can pick up for next to/well nothing really and I plan on using it for a bit. Any one have any experience with adding BG MOA to their motors?
Re: Oil additives, what do you use?
Posted: April 1st, 2012, 3:32 pm
by SuperK
I used lucasoil in my four banger, it helped quiet down the HLA's... other than that, I like to use seafoam from time to time between oil changes.
Posted: April 3rd, 2012, 8:51 pm
by mikeinaus
ive read some bad things about lucas oil... my last oil change i put in some kleen flo oil treatment and it completely silenced my noisy lifters for a while. i think im going to try kleen flo valve and lifter additive next time if i can find it
Posted: April 3rd, 2012, 9:26 pm
by Daninski
Synthetic oil that's it unless your looking to flush your system. Lucas can cause foaming and that's not good.
Posted: April 3rd, 2012, 9:47 pm
by Nd4SpdSe
Added Lucas to stop burning oil in the old 626, worked great.
Now, I just add oil to my gas :freak:
Posted: April 3rd, 2012, 11:48 pm
by mitmaks
I've used some Rislone rear main oil stop leak on our 96 Lexus ES300. It didn't stop leak, had mechanic change it out
Posted: April 9th, 2012, 3:44 am
by wagZE
I put this in CONSTANTLY at least every other fill up in my kl mx3. I run cheap gas though. I put it in all my cars actually.
As far as oil additives I tried CD2 in a 3000gt I sold earlier this year. It really quiet'd up the noisy lifters. I have tried the STP blue bottle iin my gf's sohc vtec civic before we sold it. It is suposed to help you stop burning oil, didn't work at all.
Posted: April 9th, 2012, 9:10 am
by SuperK
I guess the lesson learned is snake oil is snake oil, no matter what brand they put on the bottle..
Posted: April 16th, 2012, 1:24 pm
by Josh
I have used motor honey in the past and works decent if you have a little smoky engine, but I would not recommend Rislone. I used it in my 4 month old B6ZE motor I got from Japan and within 1 day from adding it into the oil I blew out my rings.. Back in the day I used Slick50 but you can not really find it anymore.
Now days I just change my oil frequently and put in fuel additives.
