I didn't see this in the faq or when I did a search, so if someone posted this up, I'm incredibly not sorry but woops anyways:
Not sure if the K8 is correct, since it's got two more than usual:
K8:
RPM:
0000-1900 #1 Closed, #2 Closed
1900-2600 #1 Open, #2 Open
2600-3900 #1 Closed, #2 Closed
3900-4700 #1 Open, #2 Closed
4700-6300 #1 Open, #2 Open
KL-DE:
RPM:
0000-3250 # 1 Closed, # 2 Closed
3250-4250 # 1 Open, # 2 Closed
4250-6250 # 1 Open, # 2 Open
Curve Neck:
RPM:
0000-3750 # 1 Closed, # 2 Closed
3750-4250 # 1 Open, # 2 Closed
4250-6200 # 1 Open, # 2 Open
Long Neck ZE:
RPM:
0000-4062 # 1 Closed, # 2 Closed
4062-4781 # 1 Open, # 2 Closed
4781-6812 # 1 Open, # 2 Open
Intake Manifold VRIS points
- Ryan
Re: Intake Manifold VRIS points
KLG4
RPM....0-3750....3750-4250....4250-6250....6250-7500
1..........X...............O................O..... ............X
2..........X...............X.................O.... .............X
#2 is the big one in the middle
X -> closed
O -> open
X -> closed
O -> open
Are those numbers correct? As far as I knew nothing happened until like 4250 when #1 opens. Blow my lips off.
- fowljesse
I'll look for my dyno papers. The VRIS points were set that way, by reading the dyno peaks in the various open/ closed positions, and setting accordingly..
- Josh
Why does the klg4 close back up at 6250? I would think that it would remain open until redline
- Ryan
The VRIS tubes aren't designed to flow, they're designed to resonante.
B6DE will be in the manuals.
