Idle problem V6
Rallebabz
Idle problem V6
Post by Rallebabz »
I have a mazda mx3 1.8 v6 24v. I have a problem with my engine can not stand idle when it is hot and I just got switched to a new engine and it still has the same problem, so it must be something electronic, but I can not figure out what it is.
is there anyone who can help me?
Ryan
Re: Idle problem V6
Post by Ryan »
Check the accordion tube in the intake for leaks, and after that, you'll more than likely wind up with a new distributor.
issues when hot -> distributor.
Rallebabz
Re: Idle problem V6
Post by Rallebabz »
its two different motor, with the same probleme, in one car?
Re: Idle problem V6
What parts were with the old engine that your using with the new engine? If your reusing parts like the intake accordion tube as Ryan says it could be cracked so check it.
Rallebabz
Re: Idle problem V6
Post by Rallebabz »
i have only use the generator from the old motor
Re: Idle problem V6
If your engine has an EGR that cold be that problem. You could try SeaFoam in your engine and if that helps it's probably the EGR.
http://www.youtube.com/watch?v=DjXViwb9 ... re=related
