![Confused2 :confused2:](./images/smilies/confused2.gif)
Ok, so when I'm driving at all times my car makes me bounce like crazy. It's embarrassing and uncomfortable
![Idea :idea:](./images/smilies/icon_idea.gif)
Thanks.
![Werd :werd:](./images/smilies/werd.gif)
This^ clicked mine recently to normal setting after being on the lightest and the bouncey bounce is all but gone.Josh wrote:Also check your dampening. My car was bouncing all over the place as well when I got it and it was because the coils were set at the lightest setting. It was just too light for the springs, so once I set the dampening, it now rebounds like a champ, no bouncy bouncy... I hate that feeling. They are 12 way adjustable, and I ended up going 6 clicks up front and 4 in the rear to find a good tolerable setting
That's an interesting way of doing it. I assume that the proload springs are available in a range of spring rates and can be changed to increase or decrease the proload on the main spring.Josh wrote:The small spring here is the preload spring.![]()
One of the reasons I dislike just Ground Control setups, so I added H&R preloads.
Also, it’s hard to tell what’s going on in this preloading photo. Could you please explain a little more. Could I have a link for those preload springs please?Josh wrote:The small spring here is the preload spring.![]()
soft will let your dampers move "quicker" and hard won't, right now your dampers are probably set all the way soft or close to all the way, try turning them a couple clicks to hard and see what happensMurdastylez15 wrote:Tons of information. I really appreciate the words of wisdom here.
I will have to read up more on dampening and preloading. I tried to cheat by loosening my springs while they were still on my car...FAIL. On my front camber plates there’s a dial that states Soft to Hard. I can turn the dial left for Soft and turn right for Hard, is this the same as dampening? If so, what other options of dampening do I have with this set?
