fe3 into a mx3
mazdaguy25
fe3 into a mx3
Post by mazdaguy25 »
OK guys i have my mx3 put up for the winter and i want to do the fe3 swap into what do I all need to make it work right in the car. My mx3 has the 1.8 bp in it right now.
Evo_Spec
Re: fe3 into a mx3
Post by Evo_Spec »
you should check or ask these guys here http://www.clubprotege.com/forum
they have a lot of FE3 swaps going on and probably more info on them.
i imagine there wouldn't be extremely much to do since you already have a BP
Evo_Spec
Re: fe3 into a mx3
Post by Evo_Spec »
here's some info i found on an amazing swap worklog
FE3-323 wrote:Swapping in a FE3. requires less different parts then a KL swap.
a Kia FE3 can be found in the JY for the same cost as any other motor.
MX6 2.2(NA) transmission/axels (same cost as any other in the JY)
uses existing BP front rear/top rubber engine mounts.
uses existing BP rear/top engine mount brackets
uses existing transmission crossmember
uses existing BP shift linkage
uses MX3 V6 beltside engine mount
you can buy a front engine mount bracket from me
you can buy an A/C bracket from me
you can buy TB adapters for **full mazda FE3's only**
BP/t management can be used
BOLTS RIGHT IN! (no cutting needed)
but then again. not a single other member has enough balls to just drop one in. I seriously don't understand that one.
So virtually the same cost as a BP swap
his worklog can be found here http://www.clubprotege.com/forum/showth ... t=FE3+swap
Ryan
Re: fe3 into a mx3
Post by Ryan »
Just today I started looking at FE motors.
I generally had no respect for them, but the FE3 is decent. It is a really good base. Strong block, strong bottom end, square, ideal rod ratio, dual spring up top... I just never knew about it. Too bad, its a neat motor. Better than the BP if you ask me.
There's still other garbage F motors out there. The F2 2.0's in the 2g probes/1g 626/mx-6, the 1.8 in the pre 96 626, the FS crap in the early 00 proteges...
onlytrueromeo
Re: fe3 into a mx3
Post by onlytrueromeo »
Ryan,
FE3's are probably a better engine swap than KL's...but shhh I don't want to hear it. I love KL's for their power, sound, and the fact that its not a 4 banger.
Here is the power of a FE3
http://www.youtube.com/watch?v=MJqBkD2zwgA
Rafi's machine
Mazda Mx3 FE3 Powered
Block: Stock FE3
Rods: Stock FE3
Crank: Stock FE3
Pistons: 4G63 Wiseco Pistons @ .040 Bore to get 86mm
P-Pins: Wiseco
Piston rings: Wiseco
Main bearings: Stock FE3
Rod bearings: King
Oil pump: Stock FE3
Oil filter: Nippon for Mazda
Flywheel: stock FE3
Clutch: Clutch Net solid
Pressure-plate: Custom One (Double Diafragm with an ACT and Stock one)
Head: Stock FE3 (now with Vr6 springs)
Head gasket: Stock FE3 Reused, jajaja
Head Fasteners: Stock FE3 Reused Too
Plugs: NGK
Wires: Accel
Timing belt: Stock FE3
Alternator: Stock
Exhaust manifold: Custom
Exhaust system: 3" Downpipe
Turbo: Garrett TO4E .60 trim / .63 stage 3
Wastegate: Tial 38mm
Boost controller: Craftman
BOV:HKS SSQBOV
Intercooler: Ebay one 31"x12"x3"
Piping: Custom 2 1/2"
Fuel pump: Bosch
Fuel filter: N/A
Fuel lines: -10 Braided line from the Fuel Cell to the Fuel Rail
Fuel injectors: 880cc Precision Injectors
Ignition: DSM CAS modified to fit, Waste Spark coils from Electromotive
Engine management: Microtech LTx8-s
Knock detection: n/a
Monitoring: Autometer gauges, Microtech Hand Set
Boost: 28psi
Revlimit: 7500rpm
ET: 10.8 @ 129mph
WHP: 425whp/ 384TQ
Evo_Spec
Re: fe3 into a mx3
Post by Evo_Spec »
makin me want an FE3.....
Ryan
Re: fe3 into a mx3
Post by Ryan »
Yup... thats a nice build. Crazy that he quadrupled the stock HP on the stock bottom end, lol.
onlytrueromeo
Re: fe3 into a mx3
Ya, that's why I think it's an awesome motor. 10 second MX3 on a 4 banger. Minimal cost to get there, this is it.
Though I would not give up the KL scream for any other motor in there. It's been a year since I've driven her, and it's killing me. (Though our new Mazda 3 helps quell that)
Ryan
Re: fe3 into a mx3
Post by Ryan »
The Fe3 came stock in that.
If I ever come across $10k in disposable income, I'm going to make the best 1/4 mile sleeper in my province.
Lol.
Re: fe3 into a mx3
Post by Josh »
@ OP...
The FE motor will not bolt up to your trans. You will need to get a GS trans and axles. I have heard of some guys running BP ECU's as i guess they are close but not perfect. You may need to notch out the frame rail for the crank pulley as well. Other than that it should be fairly straight forward.
The FE motor is the silent horse because Mazda did not use it here in the US. in other countries it is a well known producer of power and devastation... :) Better than a KL... stock for stock Yes imo, but a well built KL has potential. this motor would be a great addition to any RS in N/A form even. 160hp... a lot better than the 100 it cam with
The thing with the Kia is it is front to rear making it so you have to source out another Exhaust mani, intake mani, and oil pan and pick up, as well as some re plumbing for the coolent system.
