Hey Guys,
I recently have been experiencing a major problem whne im in 1st gear. After i release clutch the car will start jumping in a rthymic motion much like dancing and sometimes stall. I've been driving stick for 3 years no problem, and i have a vacuum gauge setup so i know how not to stall the engine. Any advise would be much appreciated as it is embarassing as hell to drive in the city.
1st Gear dancing
- Ryan
Re: 1st Gear dancing
My car does it too, you either have to ride the clutch or ride the throttle. Idling around at 0% throttle, especially if you coast down to it.... it'll be interesting. Car just doesn't like going slow ![Very Happy :D](./images/smilies/icon_biggrin.gif)
I think it has to do with our shitty AIC system.
- MrMazda92
Unhook your IAC, Ryan!
Stalling is a little more commonplace if you aren't kind to your clutch, but this issue is way less obvious.
- Ryan
No no, disabling stock system isn't the solution.
Removing it entirely is the solution
ITB's!![Very Happy :D](./images/smilies/icon_biggrin.gif)
ITB's!
- MrMazda92
Heh, are you IAC-less with your KL?
I just run mine unhooked, since it won't idle under 2k with it plugged in.
I near-stall when switching from reverse to 1st in my driveway almost every day, but I've yet to stall it over it. That's the only occasion it's even made a noticeable difference anyways. ![Laughing :lol:](./images/smilies/icon_lol.gif)
Sounds like a vacuum leak, throttle itself or the TPS sensor
- tehbrookzorz
+1Nd4SpdSe wrote:Sounds like a vacuum leak, throttle itself or the TPS sensor
Cody
![Image](http://i.imgur.com/Q0Vh17N.jpg)
