[WTB] Engine harness and charge harness for obd1 v6
I'm currently looking for the engine and charge harness for my 94 gs. I have a klze and as I understand the stock engine harness will work for what i need. I'm not too sure if the charge harness (from the alternator to the starter to the battery and fuse panel) is different at all. if so then i need one for the klze. I'm in Hamilton Ontario if anyone is looking to ship
Re: [WTB] Engine harness and charge harness for obd1 v6
Still looking!
Why don't you explain what your problem is. 94 is unique in so far as the ECU and disty go. Do you need to use a disty with a cam sensor for mega squirt?
Ok. Long story short this car is far from wired properly. I bought the car in October and before I could do anything to the car the starter area caught on fire while cranking. It would cranking but not start. After 3 attempts at cranking it one day I saw smoke and then...fire. It burnt the engine harness pretty badly and the wires to the starter and the pos wire to the battery. So right now i'm on a mission to fix it so i can atleast get my car running. This was suppose to be my winter project but this is a huge bump in the road. As far as ecu and disty go the car has a stock computer with a probenator chip and the does not have megasquirt. I'm sorry if you need more info but I'm still trying to learn alot of the technical stuff with this car
This is Ramsen_25 old car if that helps. He said you did help him quite a bit
- mazdaspeed23
gerald_23 wrote:I'm currently looking for the engine and charge harness for my 94 gs. I have a klze and as I understand the stock engine harness will work for what i need. I'm not too sure if the charge harness (from the alternator to the starter to the battery and fuse panel) is different at all. if so then i need one for the klze. I'm in Hamilton Ontario if anyone is looking to ship
hey i have a complete 94 harness from back to front. it includes, fuse box. all the wiring you need to install
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
![Image](http://i1187.photobucket.com/albums/z397/moneyshot23/rsz_1994155_10152926217650640_511810948_n_zps966fe00a.jpg)
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
Really the ECU is fine unless he was ODBII (which he's not since he's running a Probinator), he would just need the harness, and with the matching disty to make his life easier in trying to track down the proper one.
- mazdaspeed23
thats excatly what i had in mine, was a probinator chipped ecu, with an exteranl coil setup. still have the harness and coil setup.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
