http://cgi.ebay.com/ebaymotors/NEW-DENS ... 27bd2000cb
Mines not pumping anymore, and i need a cheap and easy fix.
Mine: 92 GS - 2.5L KLDE inside.
let me know asap so i can order something tonight or tomorrow.
Will this fuel pump fit the MX3?
- Ryan
Re: Will this fuel pump fit the MX3?
Yup.
Have you verified that the pump itself is the issue?
jump F/P and GND in the DIAGNOSIS box, then turn the key to ON. It should be quite audible both in the cabin and in the bay.
If you're not sure, leave it ON, and go unplug, plug, unplug the jumper a few times.
