Page 1 of 2
need advice please help !!
Posted: September 23rd, 2011, 6:24 pm
by gxser
i have a 96 RS DOHC!! i fried my ecu.. the code on it is B6DE and my car has been sitting all summer because i cannot find one at any wreckers around here.. someone told me that some ecu's from other cars can work for my car... my question is.. wich car,make,model would work for mine.. thanks in advance for helping
Re: need advice please help !!
Posted: September 23rd, 2011, 6:29 pm
by Ryan
The one I have in my basement will work for you.
$20 plus S&H?
The 94+ MX-3 RS was the only one with that exact motor.
Posted: September 23rd, 2011, 8:42 pm
by gxser
its B6GD my bad!!!
Posted: September 23rd, 2011, 8:58 pm
by RS_OBD'oh_2
take a pic and post it. It's probably an OBDII ecu. Is it 4 plug?
Posted: September 23rd, 2011, 9:45 pm
by gxser
gonna need a crash course on putting pics lol.. it is obdII because i scanned it a fieu times with the one i bought from crappy tire.. it has 3 plugs .. kept blowing my engine fuse like it was going out of style just by turning the key and pushing the clutch in... fried a fieu wires suprised has not caught on fire... opened the computer up to notice she was toast.. so i wanna circle the problem before putting a new one in since i have such a hard time to find one.. i have gone to pick and pull kelowna.calgary..here in edmonton and sweet nothing a guy at the front desk said that mazda 323 and protege has the same but havent found anything.. i love this car and dont feel like i should give up on her just yet..
Posted: September 23rd, 2011, 11:19 pm
by Ryan
http://www.mx-3.com/phpBB3/viewtopic.php?f=21&t=65552
Rule #1 of Pick'n'Pull's is never trust the employees to know ANYTHING specific about cars.
Seriously, trust us.
Posted: September 24th, 2011, 12:38 am
by gxser
![Image](http://i1084.photobucket.com/albums/j420/bam-bam27/WP_000171.jpg)
where my thumb is it has nothing to connect to ...
Posted: September 24th, 2011, 12:40 am
by gxser
http://i1084.photobucket.com/albums/j42 ... 000172.jpg better view of the unit with paint peeled off still can kinda tell what it is
Posted: September 24th, 2011, 12:42 am
by gxser
![Image](http://i1084.photobucket.com/albums/j420/bam-bam27/WP_000089.jpg)
this is the mess i am in right now.. due to melted wires had to rip it all off to get to it ...
Posted: September 24th, 2011, 12:51 am
by gxser
thanks for the crash course and advice
Posted: September 24th, 2011, 5:09 pm
by Dark_Rider2k3
You just inadvertedly helped me trace the interior wiring.
I did NOT know it travles that far up in the dash
![Shocked :shock:](./images/smilies/icon_eek.gif)
Posted: September 26th, 2011, 2:19 am
by gxser
i found a parts car a 94!! i wonder if i changed the whole harness if it would work on my 96? did they change much between these years if anyone knows thanks in advance....
Posted: September 26th, 2011, 11:09 am
by Ryan
Yes, 94 was a bastard child, and OBDII started in 95.
Posted: November 29th, 2011, 6:57 pm
by gxser
ok so ii got the harness and ecu from a 96 but my ecu has diferent code on it mine SAYS remanufactured B6GD and this one is just B6GD i put that in with the harness , but now the freakin thing wont start it turns over fine but i have no spark. the fuel pump will not kick in.. and my engine light will not turn on .. i had the similar problem before it was the engine fuse .. i changed the ignition switch. i have no idea what to do now any help would be great thanks in advance
Posted: November 29th, 2011, 9:43 pm
by Ryan
Dear lord. I remember this.
Poor guy, thats a horrible mess.
So you put a new 96 harness into the 96 car with a 96 ECM, and no go?
No fuel pump kickining in means that you're not getting the signals from the disty. Check between your harnesses that the distributor pins are correct, that is, each pin on the disty harness traces back to the same pin on the ECM between the harnesses.... follow?
Aside from that, if your new harness is indeed good, its just a matter of tracing it all back... start with looking for 12v and ground at the disty.
Did you ground the ECM properly? This is important, or you might cook it.
