Page 1 of 2
header question & EGR fitting size?
Posted: September 16th, 2011, 7:33 pm
by bbunkerc397
Just bought some cheap ebay headers and I bolted it all together to get a good glimpse of what it looks like, and it looks to me that the rear header is not terribly strait is this normal?
Re: header question
Posted: September 16th, 2011, 10:05 pm
by mitmaks
can you post a pic
Re: header question
Posted: September 16th, 2011, 10:21 pm
by bbunkerc397
don't have my camera tonight
Re: header question
Posted: September 16th, 2011, 11:07 pm
by Ryan
I'm pretty sure it will be okay. Just remember to bolt up the rear before the front, so you are fighting with the most leverage when lining up the front.
Re: header question
Posted: September 17th, 2011, 10:13 am
by bbunkerc397
I think my eyes are getting worse every day but I measured it and it should be OK. Also should I leave my two bottom OBD2 sensors unplugged & and my egr valve or leave them?
Re: header question
Posted: September 17th, 2011, 10:03 pm
by bbunkerc397
1. OK one problem I have is that the EGR pipe they sent was a pain to install had to bend the s--- out of it in order to install it. Also should I bypass the EGR or leave it? Is there any benefits?
2. The down pipe is touching the oil pan I'm wondering if I should heat it up with the torch and slightly bend it down? I'm wondering if this will heat up the engine oil.
3. I reused the header metal gaskets since they their reusable, has anyone else left the original metal gaskets? They are not leaking but just wondering.
Re: header question (Install)
Posted: September 17th, 2011, 10:37 pm
by mitmaks
What brand are these headers?
Posted: September 17th, 2011, 10:51 pm
by bbunkerc397
Just some ebay headers no particular brand.
Posted: September 17th, 2011, 11:27 pm
by mitmaks
Posted: September 18th, 2011, 12:01 am
by Ryan
I bought the egay ones too, mine fit ok. Only had to bend over the fron 2" or so. They don't touch the pan, but get close. They're cheaply made without a jig, so they warp differently for each unit...
Posted: September 18th, 2011, 12:04 am
by mazda915
@@ bbunker , hey bro so was in a pain in the butt to install these headers i have the same ones and goin to install em but they are ceramic coated right now so once they are ready i wil install them and i wanna know what to expect ha thanks
Posted: September 18th, 2011, 9:07 am
by bbunkerc397
Expect to take at least 3 or 4 hours to install, pain to do the rear header the front is not that bad. The EGR pipe is the hardest part I found.
Posted: September 18th, 2011, 12:32 pm
by bbunkerc397
Need some answers to what I posted, before I do anything more. Anyone!
Posted: September 18th, 2011, 6:11 pm
by mazda915
haha dam ill be expecting the hardest time consuming part . thanks man so did u notice a sound and performance increase
Posted: September 18th, 2011, 11:12 pm
by Ryan
EGR on or off is your call. Benefits and detriments to it. Personally, I found the benefits to outweigh the detriments.
I'd use the stamped gaskets they provide, they are decent quality. Keep the metal ones though. As a plus, the extra thickness will help push the Y pipe away from your pan.
The exhaust on the pan is bad. If it doesn't rub a hole in the pan, it will vibrate and be annoying.
