Page 1 of 2
Swaybar uninstallment
Posted: August 20th, 2011, 4:31 pm
by WhiteFinish
Hi Guys,
I want to install my Whiteline swaybar but getting my OEM off is a pain !!
I have tried several thing but just can't get it off.
The bolt is in somekind of joint that moves around. So the nut won't come off the bolt and I can't get the oem swaybar off
Any tips ?
Re: Swaybar uninstallment
Posted: August 20th, 2011, 5:30 pm
by Inodoro Pereyra
Posted: August 20th, 2011, 6:28 pm
by WhiteFinish
Look at the 2nd picture
Posted: August 20th, 2011, 7:22 pm
by Inodoro Pereyra
Posted: August 20th, 2011, 8:15 pm
by Ryan
Funny, when it comes to end link replacement, thats the tool I pick up first...
Posted: August 20th, 2011, 8:40 pm
by Inodoro Pereyra
Of course. There's no reason not to have some fun while working...
Posted: August 20th, 2011, 8:53 pm
by Ryan
Its like I told you earlier, I'm just ridiculously impatient with machines
Posted: August 20th, 2011, 9:39 pm
by mikeinaus
if you dont have a grinder grab a big hammer and bash the cap off the ball joint, using a flat head screwdriver as a punch. then grab the ball with vice grips and wrench it off like any other rusted bolt...
Posted: August 20th, 2011, 10:48 pm
by Inodoro Pereyra
Ryan wrote:Its like I told you earlier, I'm just ridiculously impatient with machines
Hmmm... I just love the grinder. I'm a 100% no nonsense kind of guy, and the angle grinder is a 100% no nonsense kind of machine. A match made in Heaven...
mikeinaus wrote:if you dont have a grinder grab a big hammer and bash the cap off the ball joint,
I would most definitely
NOT recommend using a BFH underneath a car on jack stands, ever. First, because in that position you will end up hitting your knuckles a lot more than the car, and second, because the vibration could knock the car off one of the jack stands, and on top of you. Not a good idea.
Posted: August 20th, 2011, 10:52 pm
by Nd4SpdSe
I tried many ways to get those links off, the only way that works...cut it
Posted: August 20th, 2011, 11:56 pm
by Sleeper6
Ya those are a pain and I would just get new sway bar links they are usually cheap enough anyhow. There supposed to have an insert at the end of the stud to put a n allen key and use a wrench on them but if they are shot your best bet is to cut them off and use new ones
Posted: August 21st, 2011, 4:48 am
by WhiteFinish
If I cut them off than I'd have to find a way to loosen the bolt on the other end... (same problem)
Posted: August 21st, 2011, 8:01 am
by Nd4SpdSe
WhiteFinish wrote:If I cut them off than I'd have to find a way to loosen the bolt on the other end... (same problem)
Cut off the bolt
Posted: August 21st, 2011, 9:35 am
by bbunkerc397
That looks very rusted, I just did a lot of work replacing my bushings and I had to remove a link to get the arm off. I used WD-40 & wire brushed the threads, with a 5mm Allen key and a 14mm wrench as able to get the nut off with damaging the link.
Posted: August 21st, 2011, 9:38 am
by bbunkerc397
If your looking to save the link and if all else fails using a small tip on a torch, if you got one at your disposal try heating it up a little that might work.
