gas mileage horrible and major oil consumption
Posted: May 13th, 2011, 4:13 pm
by pauleatstoomuch
When I first got the car before the rebuild, I was getting 32 mpg. I have a 94 1.6 dohc with 50,000 mi on the rebuild. I get a constant 23 mpg whether I drive conservative or aggressive. With AC, or without AC. I have smoke out the tail pipe at start-up and occasionally upon acceleration. The plugs are clean. I go through about a quart of oil every 400-500 mi. It runs pretty well otherwise.
Any ideas???
Air / fuel mixture off maybe???
timing belt off by a tooth???
Re: gas mileage horrible and major oil consumption
Posted: May 13th, 2011, 6:03 pm
by Ryan
A bad rebuild....
Posted: May 13th, 2011, 6:27 pm
by Daninski
Valve seals leaking hence smoke on start up. Add a quart of Rislone on your next oil change it may help reseat your rings.
Posted: May 14th, 2011, 10:49 am
by Dark_Rider2k3
I think you have 2 problems, both of which are due to the rebuild. The valve seals being the first. Do you by chance have a fuel leak? Check the injectors for leaks.
