Kia Sephia transmission
My mx3 has a bp swap from an escort gt and the g series tranny broke. Has anyone here used a kia sephia tranny with an escort gt engine? Any info would help I tried searching it already. My local junkyards do not have anymore escort gts or proteges but there are a couple of 95-97 kia sephias.
- Ryan
Re: Kia Sephia transmission
As long as they're bolted to a Mazda BP, it'll bolt right in. The Sephia trans is actually a bit stronger
do you think the input shaft is the same?? can i use the escort gt clutch and axles? same sensors?
- Ryan
All bolts together. Same shafts sensors clutch etc.
- Josh
NO, it doesn't ^^^
you will need the axles and input shaft from the Kia trans. as they are bigger by 2 splines. sensors are the same.
- Ryan
you're telling me that the Kia BP trans axles are different than the escort BP axles?
Yeah Josh is correct.
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
Dark_Rider2k3
I thought you knew that lol. Kia axles are beefier :pRyan wrote:you're telling me that the Kia BP trans axles are different than the escort BP axles?
- Josh
The Kia trans is a cousin to the 99' Mazda Speed Protege trans. same internals thats why with a little grinding you can swap the MS limited slip diff rite in. you can only use the Kia axles and not the protege axles as the Kia uses the same size hubs as the MX but larger trans sides like the Pro.
all around the best OEM trans you can use with the BP or B6.
the last swap i did we didnt even do a limited slip with it, only my custom filled polly mounts. and it layed two strips of rubber on every launch. it took the abuse well.
Ok my last question is can I use the escort gt clutch with the kia tranny or should i just buy the kia clutch at the junkyard?
- Josh
The clutch is the same, so Yes it will work.
Good luck!
Good luck!
- Ryan
I learned something today!
Thanks
Thanks
Dark_Rider2k3
That's part of the reason im using the sephia transmission. Plus for the mazdaspeed LSDRyan wrote:I learned something today!
Thanks
91EscortGT
Yeah some one said you need the kia input shaft, I believe they meant jackshaft/halfshaft/intermediate shaft whatever you choose to call it.
- garren1138
ya josh is right. If you want to while you have the kia trans you can also do a mazda speed LSD swap in it.
