Quad headlight conversion
Posted: May 7th, 2011, 7:14 pm
by youdirtyfox
Check these out!
Off a Minari kit car wich uses MX-3 headlights, and quad headlights
are an option, molded directly off an MX-3 headlight
you can seeing were im going with this cant you:lol:
Re: Quad headlight conversion
Posted: May 7th, 2011, 10:12 pm
by Nd4SpdSe
OMG this is true! I've never seen this before!
Posted: May 8th, 2011, 12:09 am
by Savin
Posted: May 8th, 2011, 1:14 am
by Evo_Spec
Nd4SpdSe wrote:OMG this is true! I've never seen this before!
same here, i was looking it up on google and thought it looked like a miata with our headlights and signals
Posted: May 8th, 2011, 2:36 am
by youdirtyfox
yep turn signals are from our 3.
I think im going to buy just one quad pod
first as they are 110$ each, to make sure
it will definately fit up with some brackets.
Think they will rock with projector units installed
and maybe one of these like I have made before
for a mates Pug 205 Mi16!
Posted: May 8th, 2011, 9:51 am
by Sleeper6
That could open up some wicked CAI options as well!
Posted: May 8th, 2011, 12:02 pm
by Mooneggs
how is this the first time we are finding out about this?!
I thought it was a miata at first as well...
yes CAI options for sure!
Posted: May 8th, 2011, 2:19 pm
by youdirtyfox
Mooneggs wrote:how is this the first time we are finding out about this?!
its quite a rare kit car over here i think .
Posted: May 9th, 2011, 10:50 pm
by PATDIESEL
Good luck- it is not likely going to be easy or cheap. I built these
a few years ago from scratch. The materials I messed up trying to get it 100% added up, but the projectors alone (Hella 90mm) were pretty pricey.
http://www.rallylights.com/ is a great place to get the lights and a good resource if you have a
very specific question.
The biggest issue I would research first is how to mount the lamps to the housing you pictured above. Hella, and most others, use a minimum of 3 mounting points. You can get away with 2, but you need the housing to be pretty aimed already to do so.
Posted: May 10th, 2011, 4:51 am
by WhiteFinish
Very cool find !!
Posted: May 12th, 2011, 1:15 pm
by youdirtyfox
PATDIESEL wrote:Good luck- it is not likely going to be easy or cheap. I built these
wow man nice touch on those!
you are right, expensive indeed after paint, and alot of time involved.
something i could put towards the turbo instead! Thanks for the advice though
It was a bit of a pipe dream, so im formulating a plan to modify some dual
projectors
If anyone wants contact details on were to buy the quad pods just PM me.
Posted: September 20th, 2011, 7:08 am
by Hammy
One thing about these pods... they are made to be moulded directly into the body of the kit car above, so there would need to be some modding to attach them to the MX.
Posted: September 20th, 2011, 9:05 pm
by MrMazda92
If the measurements work out, and the fitment can be made without butchering a bumper, then I am definitely in... Cold air here we come.
Posted: September 29th, 2011, 1:12 pm
by youdirtyfox
Hammy's right you would need some really good fab skills to get these puppys attched
properly, I priced up it cost could upwards of £450 to install these correctly with pro paint and decent beams, so on this occasion.... Im oot
