Hose question
_lithium_
Hose question
Post by _lithium_ »
Ok, so i was trying to figure out if I have a vac leak (I can hear hissing sound) and saw this but have no idea where it is supposed to be plugged into (if anywhere? ) It comes out of the block between cyl 1 and 3 as shown in the pics:
Any ideas?
_lithium_
Re: Hose question
Post by _lithium_ »
Ok I found its spot! Its on some black thing that sits below the solenoid, does that come with it if u buy a new one? The plastic piece the hose goes over actually broke off inside the hose
PATDIESEL
Re: Hose question
Post by PATDIESEL »
A "new one" what? hose? No, Mazda will sell you a new prebent hose, but it wil cost 10x the same as a unbent vac hose from any auto parts store. If you mean "new one", the plastic piece, then yes, it will have a new nipple for you to attach your vacuum hose to.
You can try super gluing the nipple back onto the plastic piece (not sure which vac silinoid you broke, but it is deffinately a vac silinoid). You can try JB Weld too, but either way make sure you do not clog the hole. Also, make sure the plastic pieces are clean and if they broke smoothly you'll need to rough up the contact faces with some sand paper or something to help them stay together.
Re: Hose question
Post by wytbishop »
The black plastic thing is the item labeled "vacuum chamber" in this picture. It's sort of important. You'll need to get one off a junk yard car. I doubt you can even buy it from Mazda anymore.
http://www.mx-3.com/manuals/showimg.php ... F2-007.gif
mikeinaus
Re: Hose question
Post by mikeinaus »
probably easiest to just get a "new" intake manifold. and by new i mean one from the wreckers.... looks like you found the cause of your rolling idle :wink:
_lithium_
Re: Hose question
Post by _lithium_ »
Yeah I'm hoping it is causing the rolling idle but idk. I JB welded the piece back on as a temp fix and will throw it on later today.
Ryan
Re: Hose question
Post by Ryan »
I think I have a set of those vac chambers laying around if you broke a nipple off.
they are critical to the VRIS system, and something else T's off of it.... I forget. Either FPR or EGR.
_lithium_
Re: Hose question
Post by _lithium_ »
Omg...I for sure found my vac leak problem.. but have NO IDEA how to fix this and what it is even called/does? Please someone see if they know anything about it and if they know a place I can buy one.
It has a hose that attachs to a metal spout on the intake mani right next to cyl 1 that is this thing:
and this is the hose/circle thing I took out:
My brother owned this car before me and said when he redid the intake manifold it broke but he super glued it back together. I also found the other side of the yellow circle thing sitting next to the cyl 3 spark plug wire,
am i screwed?
_lithium_
Re: Hose question
Post by _lithium_ »
With a bit of research, it looks like it's a one-way check valve?
can i use this as a replacement?
http://shop.advanceautoparts.com/webapp ... P2037_____
Ryan
Re: Hose question
Post by Ryan »
It is the one way valve for the vac chambers for the VRIS.
They are hard to come by :(. They need to be a good check valve if you're going aftermarket. You get what you pay for. There is a way in the manuals to test it. But it needs to hold full vacuum.
_lithium_
Re: Hose question
Post by _lithium_ »
It still affects the VRIS? It doesn't go to the VRIS at all, it drops off that spout and goes below the intake mani (on the outside) and over to where the cyl 3 is into something else. Would the link I put up be a good replacement? I'm outta options =/
Ryan
Re: Hose question
Post by Ryan »
Look at the vac diagrams. I'm 100% sure.
That chec valve fills those black chambers under the intake manifold. Those chamber provide vacuum to the VRIS solenoids when you're at WOT (zero manifold vacuum)
When you shift, it evacuates the chambers again, and then next run up the RPM range at WOT, you have vac for the VRIS again.
If it doesn't hold vacuum, you won't get VRIS past just a few flips of them if any at all.
_lithium_
Re: Hose question
Post by _lithium_ »
Sounds like I for sure found the idling problem on my car then :) which is definitely good news.
Do you think this will work the same though? (if i can't find one anywhere at the wreckers)
Ryan
Re: Hose question
Post by Ryan »
Looks good to me. Its description pretty much exactly matches what its supposed to do.
_lithium_
Re: Hose question
Post by _lithium_ »
Ok. Looks like I'm gonna take off the intake manifold tomorrow and try to just jb weld that part together to the best of my ability (it broke the plastic spout that comes out of what im guessing is the vac chamber in the intake?)
