I am currently searching the forms, but thought i would toss out the question while i search..
1993 mx3
v6
fuse's all good
Can't locate the relay
Rear wiper and rear window defroster quit working
- Evo_Spec
Re: Rear wiper and rear window defroster quit working
the relay's are right above/behind the fuse box, if you follow it up higher you'll see a metal bracket that holds a bunch of relays
yeh,,found it,red-red-b/y-2 white/red, white with red stripes melted relay plug, tried new relay, no luck, so i guess i check the cpu and the switches...
