check engine light came on but goes back off
john1983
Post by john1983 »
ok so today i started my car after it sat for a little while excluding yesterday start but i noticed while it was warming up the engine light was on and it wasnt on last time i drove it but when i tapped the gas pedal the light turned off as the rpms returned back to idle could any one help with ideas of what this could be
92 MX-3 6cyl dohc 24 valve K8 cold air filter custom exhaust drift body kit carbon fiber hood 17" focal rims Kenwood KDC-MP635 headunit Pioneer 6.5" componet door speakers and 4" rear speakers 500 watt boss amp powering 12" sony explod
My Work Logviewtopic.php?f=46&t=76603
Newfie_dan
Re: check engine light came on but goes back off
Post by Newfie_dan »
pull the codes that will tell you for sure.
john1983
Post by john1983 »
ok but y would the light go off though thats what kinda confuses me
mikeinaus
Post by mikeinaus »
you should have pulled your codes before you even posted here. your question is retarded...
Ryan
Post by Ryan »
Its called a soft code. Sometimes the light doesn't even come on, and you have a code. It if comes on and goes off, it remembers it for a few days.
john1983
Post by john1983 »
thanks ryan
Post by wytbishop »
Many codes are not stored at all as Ryan has alluded to. Some codes will only cause the CEL to comeon while the condition that causes it exists. If the condition corrects itself the the light goes out and the code is not stored. Other codes will cause the ECU to revert to a sort of "safe mode" and will be stored until the ECU is reset. If they are not corrected they will be displayed again as soon as that condition arrises again.
Ryan
Post by Ryan »
wyt is right, sorry I wasn't too clear. codes that are from an "on/off" malfunction as opposed to an "out of range" malfunction are stored differently. If you unplug your IAC, CEL will come on, plug it back in, it will go off and it won't remember it was ever not there.
Then, if your O2 reads out of range, or the two are not in agreement, etc, it will remember that condition for awhile.
MrMazda92
Post by MrMazda92 »
This literally just happened to me as well. I threw a 12, which I can't remember atm... I'm checking it now. I pulled over and pulled it immediately, but like a dumbass I forgot to unjump ten/ground before driving home. Thankfully it was ~1 mile, but it was the most unpleasant mile Ive ever driven in an mx3.
john1983
Post by john1983 »
could the code have to do with our ecu learning ability seems the battery died completely and it was relearning just a thought
chrome730
Post by chrome730 »
john man the best thing is to pull the code before you post questions on here. A SELECT FEW ARE BRUTAL ON HERE. LOL. no i love these guys. :lol: How long has your car been un hooked from a battery.
It only takes a single voice to start a revolution
Flyer
Post by Flyer »
My check engine light came on, so I checked under the hood and the engine was still there...
mikeinaus
Post by mikeinaus »
Flyer wrote:My check engine light came on, so I checked under the hood and the engine was still there...
Zing!
