what type of gearbox is it???
KINGMX
Post by KINGMX »
hi....i have a mx3 and i dont know what type of box it is using.... on the bell housing is a paper stamp with F505 on it.......on the housing lower down on the box has F5D2?????? :? :?
is it the F5m-r or the F25m-r????? which one???
thanks......
Newfie_dan
Re: what type of gearbox is it???
Post by Newfie_dan »
if its the 4 cylinder then its most likely the f25m-r, the g series trans are much stronger than the f series trans if you are looking to swap then I would opt for the g series.
Post by wytbishop »
I believe the F25M-R was first manufactured in 94'. F5M-5 was it's predecessor.
Ryan
Post by Ryan »
If you can shift into reverse while still rolling without grinding it, you have a F25M-R.
If you can't, F5M-R.
KINGMX
Post by KINGMX »
thanks ryan...its a f5m-r...neat trick....lol.
Return to “Transmissions”
