does anyone know how much paint i would need if i was going to paint my mx-3?
im thinking about painting is the rx-8 r3 blue http://www.mazdausamedia.com/files/imag ... fascia.jpg
what do you guys think?
how much paint is needed to paint my mx-3
- mitmaks
Re: how much paint is needed to paint my mx-3
That really depends on what paint you'll buy. Cheaper paints don't cover as well, so you're ending up putting more coats of cheap paint rather than 2-3 coats of expensive paint. Also if you use sealer it will help. Ie if you're painting yellow car, use white sealer, if you're painting blue car use gray sealer.
Are you painting jambs, engine bay?
- djfinn
yea i will prob get them painted as well there is no sense in doing a half a-- job. how many gallons would you say i need for an expensive paint
- mitmaks
A gallon will do car that's mx-3 size. You will have 2 gallons sprayable as it's usually 1:1 mix.
