Help Me get this BP running right
Posted: December 2nd, 2010, 8:50 pm
Hey all, I figured i'd start an actual thread about this vs have my intro thread evolve into something it's not.
So. refresher.
Bought Rekognize's bp swapped mx3
LOVE the car.
HATE how the swap was done by the shop that not suprisingly seems to have flopped and packed up shop (no answer on the phone, emails, ect, not even a voicemail)
The car will NOT hold 2500 rpm in neutral rev while warm.. but will while cold (while warm, rpm surges from 2000-2500 but wont stay at 2500)
The CEL does not come on at all (even in acc on)
the battery light does not come on at all (even in acc on)
Ive been told the car is running a stock modified harness, B6 ecu and B6 maf.
The motor (since it's B6ecu wiring bits) doesnt have the full potential it should.
Guzzles gas. 280-300 a tank GRANNYING.
and bucks violently unless careful with the gas pedal under part throttle or low speed crawling. i've found the sweet spot in the pedal.. so it's substantially better.. but sometimes it still catches me sleeping.
the vics was a nightmare (didnt even work when i got the car)
everything was routed wrong.. stuff looped into stuff, stuff just taped off.. i discovered vics not working after taking it for a hard drive and noticing the piss poor power.. upon inspection under the hood with the car free revving via throttlebody... the VICS diaphragm was NOT moving....
used chilton's manual to redo the vac hosing for vics, now it works like a charm. ( used protege 1.8 vac diagram)
and there were a few vac solenoids plugged into the fuel inj harness near the VICS solenoid plugs.. but all the vac lines to these solenoids *NON vic* were looped into themselves... what gives???
since fixing vics.. the car definately pulls stronger.. but still feels weak compared to what i'd expect..
other notable things.
im 100% positive the car is running a rs tranny.
im 100% positive the car is running a maf not a vaf.
what do i need to do to run a bp ecu/vaf on this motor?
What do i do harness wise.. do i modify it more? can i swap in a escort gt manual harness?if so, what do i need to do wiring wise? splicing, repinning, ect, ect, or just change a few plugs??
So. refresher.
LOVE the car.
