How can I do a voltage sweep on a VAF?
Posted: November 16th, 2010, 2:43 am
by spete701
A few people seem to be having this problem. But they understood how to connect a multimeter to a VAF and test for voltage, rather then resistance. The wire harness to the VAF is in good shape. I do not want to cut into it, exposing the wires, and I doubt that's required. So, how in "Hells Bells" can I connect my multimeter to my KE50 VAF?
Is there some lead that I can clip into?
I'm going to re-read these forums.
http://s27494.gridserver.com/phpBB3/vie ... 56&start=0" onclick="window.open(this.href);return false;
Re: How can I do a voltage sweep on a VAF?
Posted: November 16th, 2010, 8:41 am
by Ryan
I don't know what they call them, but its just a tool with a pointy end and an alligator clip on the other end, so you can poke a tiny hole in the insulation and get the reading.
Posted: November 16th, 2010, 8:45 am
by Inodoro Pereyra
You take 2 straight pins (you know, like the ones tailors use to hold the fabric when they're sewing a suit), and you stick them into the back of the connector, to the power and ground terminals. Make sure the pins are making good contact with the wires by measuring their resistance before putting everything in place.
Once you did that, put the connector in place, turn the ignition to "ON", and check for voltage. You should have battery voltage.
A voltage sweep is not gonna give you any information you don't already have with a resistance sweep. Either way, you have to remember that passing both tests does not guarantee that the VAF is working properly.
Also, check the terminals in the female connector, as they have a tendency to open up. If you suspect they may not fit tight enough against the VAF's pins, try tightening them up with some thin wire or something, or replace the connector.
