FS: Two K8's, mx3 blown trans, *CHEAP**abbotsford, bc*
Thought i would post this stuff up for sale before i take it to the scrapyard
I have two complete K8's with the intake/exhuast manifolds attached with the TB's and injectors etc.
The first one i got from pick a part but chose not to use it because the spark plugs were out and some water got in there and rusted the cylinders up a bit. Engine still turns over and get compression and im sure would run if you put a but of oil down the cylinder and let it run for a bit. Otherwise its totally rebuildable. No bent valves or anything and it came from a car with 180 000 km's on it.
The Second engine got overheated and blew the headgasket or warped the heads. It was blowing white smoke and over-pressurizing the cooling system. Car still ran fine besides that so im sure new headgaskets and machine the heads a bit and it would also be fine. engine had 250 000 km's on it.
Have a k8 blown auto trans for parts if anyone interested.
k8 engines - $20 each
blown tranny $free
have other various parts if anyone wants them and i can take parts off the engines and sell them separatly such as manifolds, injectors, wiring harness parts, sensors, heads, valve covers, Exhaust Y pipe.
Best way to get ahold of me is to email be at:
bretthav@hotmail.com" onclick="window.open(this.href);return false;
blown tranny $free
Re: FS: Two K8's, mx3 blown trans, P**abbotsford, bc*
Bump. Parts are still availible!
Everything changed to FREE if you pick it up
If I have to take parts off and ship then I have to charge a min amount.
Re: FS: Two K8's, mx3 blown trans, *CHEAP**abbotsford, bc*
I dont need any atm but I would definatly save the tensioners before you toss the engines. Never hurts to have a spare, Ik the powersteering ones like to break every now and then
Ya I'm going to pull off that stuff and keep it in boxes
Also have crank sensors, knock sensors, harmonic balancer, throttle bodys, intake manis and fuel injectos and rails all for a k8.
Also have a good shape clutch and flywheel from a 5speed k8
- MrMazda92
Am I to assume the flywheel is a freebie as well?(Not including shipping)93Colttsi wrote:Ya I'm going to pull off that stuff and keep it in boxes
If so, how much shipped to 97402?
$20 for the flywheel +shipping
Email me if you want a prompt response
Bump
Bump
- MrMazda92
Hmm, My plans have changed slightly for my build; You should have NO problem unloading flywheels on ProbeTalk or MX6.com though, the KL Flywheel is a beast. They'd buy it fairly quickly I imagine.
- mitmaks
I'm looking for front bumper reinforcement if you have one
If you're parting them out, I'll take the spring retainers!!
92 Mx3 GS KLZE 5 speed
97 Dodge Dakota - Boyd rims, custom built 5.9 360, custom tranny with kevlar guts and shift kit. Too many upgrades to list.
92 Mazda 323 - winter beater
mx3 by Leadfoot Lesley, on Flickr
Ya two complete k8's still sitting around
How much do the k8 flywheels usually sell for?
Also what would you pay for all the retainers if I was to remove them
Sorry no body/chassis parts. No re-bar
Anything else I should grab from the engines before I bring them in for scrap?
I dunno, how much work is it to remove them? If you can come up with a price to make it worth your time, let me know.
