need help!
focort klde_beast
need help!
hey need help i keep looking and looking for sites that sell parts to supe up my klde and i have yet to find some. im jus wanting to rebuild the whole motor and make it high compression and run all motor no turbo but stuck anyone know any good sites?? thanks
focort klde_beast
Re: need help!
ment k8de not klde
- ice_mann
Re: need help!
Since you already have the k8, the best thing that you could do is swap in a klde or if you have a bit more money the klze. Theres way more aftermarket support for the kl engine, check the worklogs to get ideas of parts and whatnot.
95 MX3 GSZE- Silver, TWM STS, suspension techniques lowering springs, moroe struts, bronze-oil shifter bushings, leather MS shift knob, strut bars(Fleabay), ss headers, spec stage 3 clutch, fidanza flywheel , outlaw spacers, MS motor mounts , custom ss door sills, spyder projectors
WTB
coilovers
Megasquirt(dont know which one yet)
Slim Fans
WTB
coilovers
Slim Fans
- Ryan
Re: need help!
There is no such thing as 'souping up' a K8. It was never meant to be a performance motor, and no one makes performance parts for it. Not real parts, anyway.
Your first step is swapping in a 2.5 KLDE block, and build that. No point in buying a ZE if you're going to replace the cams/pistons, since thats pretty much all that makes them special (and some argue the heads flow better)
focort klde_beast
Re: need help!
damn lol i jus wanted to basically rebuild it top to bottom and port and polish all the goodies i can really. but i dont care how much power i get out of it honestly jus enough to be sweet. i have found some stuff for it but i didnt wanna go with the kl. jus mainly to be different
Re: need help!
If by sweet you mean "soup up" to an additional 5-10hp, then yes, that would be do-able...
It's subjective; my brother in law thinks his 5hp go kart is sweet, whereas my father-in-law thinks that a V8 motorcycle with a 150 shot is sweet....
It all depends on what you want in the long run.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
- Inodoro Pereyra
Re: need help!
Ryan wrote:There is no such thing as 'souping up' a K8. It was never meant to be a performance motor, and no one makes performance parts for it. Not real parts, anyway.
Whoa...! That's a little extreme...
Actually, the K8 is more powerful (relative to its displacement), than the KL-DE.
True, there's very little aftermarket stuff for it, but that hardly means there's nothing you can do to it. There's actually a whole lot you can do, and I'm willing to bet, if you take your time with it, you could get into KL-DE territory, or even a little higher.
The only difference is that, instead of bolting stuff on it, you need to work on it, and you need to know what you're doing.
However, I agree: if you don't want to spend the time, or if you're looking for the best bang for the buck, a DE is definitely the best investment.
Diogenes of Sinope.
Diogenes of Sinope.
Re: need help!
Not without spending 2x-5x the price of a KLDE worth of work into a K8,Inodoro Pereyra wrote: I'm willing to bet, if you take your time with it, you could get into KL-DE territory, or even a little higher.
- Inodoro Pereyra
Re: need help!
Of work, yes. But hardly any money, for other than machine work.Nd4SpdSe wrote:Not without spending 2x-5x the price of a KLDE worth of work into a K8,Inodoro Pereyra wrote: I'm willing to bet, if you take your time with it, you could get into KL-DE territory, or even a little higher.
And there are freaks out there (like me, for example) who actually enjoy spending hour after hour, buried in grease up to their eyeballs, working on an engine.
Diogenes of Sinope.
Diogenes of Sinope.
Re: need help!
If you want to make it different and spend lots of time try to make itbs.
http://www.themazdaforum.com/showthread ... -a-Protege" onclick="window.open(this.href);return false;
the link just shows a picture of a potential design for klze itbs
93 GS/SE
Sleeper6
Re: need help!
http://www.google.com/imgres?imgurl=htt ... s%3Disch:1" onclick="window.open(this.href);return false;mxmikey wrote:If you want to make it different and spend lots of time try to make itbs.
This is it for real... when i get rich n famous I will have one turbo 6 and one with this setup!
Re: need help!
I read a few topics this summer of people swapping the k8ze in if that would interest you.
93 GS/SE
- Dentfixer
Re: need help!
Mate forget all the negs, you can do a fair bit to the K8, gsxr1000 throttles bodies with taller trumpets, cams, bore it. Over here in Aus we are a bit limited access wise to the larger motor and parts ect, so we make do with what we have. Find yourself a spare K8 from a wrecking yard and have a play around with it. Just because other people can't be bothered doesn't mean you shouldn't have a go
forget the cash side of it, just chip away at it slowly get the bits you want each week and then whack it all together and 'Bobs ya uncle'
Re: need help!
Hey I heard of a motor call a KLZE, suppose to have a few more balls then the K8 and you simply install it and enjoy the HP gains. Someone called Mazda made it but then again what the hell do they know.
Re: need help!
Dan, there you go talkin out your rear again.... geesh. Those ZE's are only fabled creatures
