bpt engine wont kick over
Posted: September 11th, 2010, 3:14 am
by omx394
hey i recently put a mazda bpt turbo into y 30x(mx3) had a b6 motor in it to start wth
put the bpt wiringloom and ecu aswell
prolem is it wont start starter isnt even clicking
all lights on dash work though any1 hd this problem before
thanks
Re: bpt engine wont kick over
Posted: September 11th, 2010, 6:31 pm
by Newfie_dan
you are not getting any power to the starter from the ignition switch, make sure that you connected that right and check for blown fuses.
Posted: September 12th, 2010, 12:10 am
by Evo_Spec
BP engine fuse is 15amp and not 10amp like the B6.
also if you have a 94+ you have to swap 2 wires, otherwise that'd be blowing your engine fuse if not swapped.
Posted: September 12th, 2010, 9:12 pm
by omx394
i swapped the 2 wires over . which ones the engine fuse and ho do i know if its blown
Posted: September 13th, 2010, 7:23 am
by omx394
i red in a post you need to use the origianl mx3 ecu not the gtx is that right
Posted: September 15th, 2010, 8:04 am
by omx394
i just read if there is an immobiliser on the car and its intergated into the standard ecu it wont start with the new ecu
