Protege Motor and Tranny into an MX3
I have a 93 MX3 and the tranny is going bad and the motor is got too many miles on it, would a Motor and Transmission from a 94 Protege work in it? If not what motor and transmission would you recommend?
Re: Protege Motor and Tranny into an MX3
Mazda MX6 motor an transmisson would work best.
- Ryan
Don't go giving out answers like that...
If you have a v6 MX-3, then the KL v6 motor form a MX-6 is fine, but since you're suggesting a protege, I'd say he has a 4 cylinder, and hte MX-6 4 cylinder will NOT fit.
If you have a 4 cyl, the best stock upgrade is the 1.8L DOHC from a protege/escort GT. any 1.6/1.8 SOHC will bolt right in too.
All B series trans/motors interchange.
Beware answers from members with single digit post counts.
Thanks Much
would a motor and tranny from a 99 escort zx2 fit?
- Ryan
The 1.9L zetec or ecotec or whatever it is has been done. I don't remember by who.. I think it was over on Club Protege. but why?
Because I need a new engine and transmission...and I was hoping to jus buy a complete car and pull it out and put them in my car...unless you know a good place to get an engine and tranny for cheap
- Ryan
It depends where you live.... plenty of scrap yards let you pull motors yourself. Personally, I can get an entire engine/trans/all attatched bits for <$300 if I pull it myself.
Which is exactly what you can do with a Protege...as stated in post #3. The BP or B8 or B6 from a variety of sources will bolt right in and run with relative ease. There's tons of information on 4Cyl swaps in the 4cyl FAQ section. A bit of quick readign will clarify most of your questions.Helton10 wrote:Because I need a new engine and transmission...and I was hoping to jus buy a complete car and pull it out and put them in my car...unless you know a good place to get an engine and tranny for cheap
- Inodoro Pereyra
Sure... Or you could just swap for a Mack truck engine...spidlemx3 wrote:Mazda MX6 motor an transmisson would work best.
![Image](http://i580.photobucket.com/albums/ss247/Inodoro_Pereyra/mackmx.jpg)
You may need to replace your ECU though...But, hey! Chicks dig it...
Diogenes of Sinope.
Diogenes of Sinope.
Inodoro Pereyra wrote:Sure... Or you could just swap for a Mack truck engine...spidlemx3 wrote:Mazda MX6 motor an transmisson would work best.
Victory!!!!
Helton10 wrote:would a motor and tranny from a 99 escort zx2 fit?
Ya, but those types of swaps aren't bolt-in and require mechanical knowhow and tools to fabricate custom parts for mounts and such.Ryan wrote:The 1.9L zetec or ecotec or whatever it is has been done. I don't remember by who.. I think it was over on Club Protege. but why?
- MrMazda92
Don't forget ebay chips, made my h22 vtec 600 WHP for $19.99!!!
- solo_ryder
Why wont a fs-de fit
