so, i recently seafoamed my tb, used the TEn and GND method to adjust the idle (went up 500rpm after cleaning) and set it to 1000 rpm. everything was normal till today, it is rainy and cool. it started fine, but when i went to drive off after about 2 mins of idle, it acted like it did when i had a bad wire. this went away after it reached normal temp. BUT now the idle sits at 1000 when i sit and idle, and if i rev it it drops to 600 briefly then returns to normal (1000). when i push the clutch it drops to 600 ish and if i rev it w/ clutch in, it stops at 1000 for a second then goes back to 600-700. when i let the clutch out, it slowly (about 10 sec) creeps back up to 1000.
can anyone tell me if this is normal behavior? or should i be :welder:ing the tb and jerry rig a carb XD
