Adjusting Projectors?
Sleeper6
So i put in the new headlights and they are amazingly bright but only one downfall... its in the wrong lane lol. Anyone else have projectors and know where the adjusters are to save me wasting to much time tomorrow? I figure theyre in the bulb cavity but thought maybe someone else might have done this first
- Mazdaspeed96743
Re: Adjusting Projectors?
Are these the Spyder MX3 Halo Projectors? If so then the adjuster that adjusts the height is behind the headlight and if you look stand over them it should be right there it is an 8mm bolt I believe..
8mm bolt is the other adjuster that pans the projector left and right, The other adjuster is beneath the rubber boot that protects the head light from moisture. It is in a kind of hard area but I believe I got it with a swivel..
I'm sorry if this had sound confusing but if you don't get an answer by tomorrow afternoon i'll help you out and take a pic on the exact location it is just too dark now to go outside and take pictures right now.
Sleeper6
Mine are the spec d with the three leds to the outside of the lamp. Anyone familiar with these?
Sleeper6
Alright so I had a chance to slide them back out and found some adjuster screws (I hope) that were tucked under the support when they were installed. Im going to pull them out and if they work Ill post a diagram for which adjusts which for future reference
