Page 1 of 2
Car shuts off while A/C is on and coming to a stop.
Posted: July 17th, 2010, 5:43 pm
by jkbreazeale
93 B6ME with 5-Speed tranny. When the a/c is running, I can be coming to a stop and the car is likely to shut off. If I am slowing down going into a turn and apply the brakes the car will turn off. What would cause this? If the a/c is off, there is not a problem whatsoever.
Re: Car shuts off while A/C is on and coming to a stop.
Posted: July 17th, 2010, 5:45 pm
by jkbreazeale
Wow... I am seeing three posts down that JCS just posted the same problem with a couple of options to fix.
Posted: July 19th, 2010, 12:41 am
by JCS
Yeah, still not real sure why other than lack of power.
Posted: July 19th, 2010, 12:58 am
by RS_OBD'oh_2
this is not all that hard to grasp.
AC puts load on the engine.. your engine is a wuss and can't handle it. You can try to upgrade your ground wires and a basic tune up.
Keep in mind the car does not "shut off," it stalls. Big diff.
Posted: July 19th, 2010, 12:49 pm
by jkbreazeale
Adjusted throttle position sensor. Problem solved. However, upgrading to better ground wires may be in the near future too.
Posted: July 19th, 2010, 12:52 pm
by jkbreazeale
RS_OBD'oh_2 wrote:this is not all that hard to grasp.
My engine is not a wuss
Posted: July 19th, 2010, 2:52 pm
by Daninski
jkbreazeale wrote:RS_OBD'oh_2 wrote:this is not all that hard to grasp.
RS_OBD'oh_2 then says 'is too'
jkbreazeale then says 'is not'
RS_OBD'oh_2 'is too'
jkbreazeale 'is not'
then comes the big decisive comment
jkbreazeale 'Oh YA!'
Posted: July 19th, 2010, 5:29 pm
by Mi|<E
Then I pipe in and say yes your engine will stall out under 1k rpm with
any braking applied. Mine did with no AC and good compression across
all cylinders in the DOHC B6.
Posted: July 19th, 2010, 9:30 pm
by jkbreazeale
Well adjusting the tps was a cure all for this situation. No more stalls! And "IS NOT!!!"
Posted: July 19th, 2010, 9:34 pm
by RS_OBD'oh_2
Good
IS TOO!!!
Posted: July 19th, 2010, 10:27 pm
by jkbreazeale
For the sake of humanity I will agree to disagree.
Posted: August 13th, 2010, 9:46 pm
by Mrfishydude
my stalls sometimes too, even without the a/c on. Mostly it just idles so low the engine rocks the car. Is it the throttle position sensor I need to adjust? if so how? and is that different than adjusting the idle?
Posted: August 13th, 2010, 10:33 pm
by RS_OBD'oh_2
probably a vac leak. Too many reasons to narrow down
Posted: August 14th, 2010, 12:05 pm
by tripleMX-3chicMS
LOL, I used to say that about my old one.... But it was a wuss.... i sold it.
Posted: August 14th, 2010, 5:36 pm
by OkieOFT
My car runs pretty rough while in gear with the A/C on. Taking it out of gear or killing the A/C smooths it right out. It's an auto, btw (hoping to fix that soon). It's never died but it does shake the car like godzilla was farting on it.
