mx3 turbo header?????
ok sry if someone has asked this ? but i couldnt find it. im trying to find a mx3 1.6 b6 turbo header and iv been looking at the miata headers for the 1.6 b6, the bolt pattern seems to be the same but idk. could someone help?? thanks
- RS_OBD'oh_2
Re: mx3 turbo header?????
http://www.mx-3.com/phpBB3/viewtopic.php?f=3&t=74415" onclick="window.open(this.href);return false;
for future ref', this would be in the FORCED INDUCTION section
the year of your car is also very very important, please list as much info as poss. Any question you could ever have, has already been asked before. Keep in mind this car is not new.
http://www.mx-3.com/phpBB3/search.php" onclick="window.open(this.href);return false;
thanks for the link but the header he has he got from TJS and i dont like the looks of them and its not realy a header it more like a man manifold. the header from a miata points up and i done care if it dous i just want to no if the bolt pad is the same?? the miata 1.6 dohc and the mx3 1.6 dohc are thay the same
- RS_OBD'oh_2
So you don't like the look of a log? Ya, a hella strong design - supporting 600hp sux. what do you mean by header? tube-runners? Oh, and mine is not from TJS - I have no idea who they are.
http://www.mx-3.com/phpBB3/viewtopic.ph ... 5&start=15" onclick="window.open(this.href);return false;
these are the main options. The miata bolts are the same... but you'll probably buy some 100.00 POS mani that will crack. Keep in mind, the flange on the mani dictates the type of turbo you will use. Have you decided what turbo you want to use?
Try searching
Try searching
- RS_OBD'oh_2
next time.. one post with the same crap will work.
ya and you still cant help. i asked for an answer and still dont have one
sry didnt see all of it. im at work and didnt take the time sry about that man thanks
ya im going to yous a t3/t4 turbo
