Sea Foam: How to
ice_mann
Sea Foam: How to
Post by ice_mann »
This is right off the Sea Foam website:
1) Make sure that you car is parked in a well ventilated area. Locate the main vaccume line that you are certain distributes evenly to all cylinders. On many vehicles the easiest option is taking the vacuume line from your brake booster PCV. If you are not certain take your car to a certified technician.
2) start the car, for automatic transmissions keep the car in park, for manual transmissionskeep the car in neutral and apply the park brake. Slowly pour 1/3 to 1/2 can of Sea Foam motor treatment into the vacuume hose, while at the same time rev your engine to about 2000 RPMs. You will begin to see clouds of white exhaust from the tailpipes. When you have finished pouring, shut off the engine and let it sit for at least 10 minutes.
3) Start the car again and drive aggressively (but legal) for about 2 to 5 miles (3-8 kms) or untill the white smoke is no longer produced.
sources
http://www.seafoamsales.com/how-to-use- ... tment.html" onclick="window.open(this.href);return false;
95 MX3 GSZE- Silver, TWM STS, suspension techniques lowering springs, moroe struts, bronze-oil shifter bushings, leather MS shift knob, strut bars(Fleabay), ss headers, spec stage 3 clutch, fidanza flywheel , outlaw spacers, MS motor mounts , custom ss door sills, spyder projectors
WTB
coilovers
Megasquirt(dont know which one yet)
Slim Fans
