plz help me engine troubles
i got a 1.8 stock mx3 gs. the other day it stopped running and i read the codes it read crankshaft ne2 sensor and tps sensor. i bought a tps and the crank sensor had frayed so i reapired it it ran fine, i was curious to see if the old tps would work so i put it back in and it did work fine and also brought my idle back to normal where as b4 it was bout 1500. now 1 week later the car will not idle without stalling i must give constant gas and low rpms r rough but in the high rpms it runs normal and great ne ideas to wats rong?
- Ryan
Re: plz help me engine troubles
NE2 is the crankshaft position sensor in the disty. It requires you to replace the entire distributor.
Your idle should be half of that. 650+/- 30 rpm.
Set the idle properly. Warm her up to operating temp. Jumper TEN and GND in the DIAGNOSIS box. Start the car. turn off all electrical loads, and make sure the fans aren't running, etc...
Twist the big screw in the top of the throttle body till its about in spec.
While you're there, you can set the TPS. Adjust it until the fan comes on, and then slowly slowly move it back untill the fan jsut turns off. this is the cheap way, but it works.
bouncing idle/stalling is commonly caused by vacuum leaks. check the main accordion tube for cracks, and other vac lines that may have been forgotten.
- SpatialTerror
umm im not a moderator. but ya this was poste in da wrong place
SpatialTerror
SpatialTerror
