ignition
Posted: April 26th, 2010, 1:09 pm
by blue93
just wondering.. any idea on which cars would the ignition switch be interchangeable with my 93, sohc, 4c .. possibly the 1st gen protege or 2nd gen 323? Thanks
Re: ignition
Posted: April 26th, 2010, 1:14 pm
by Ryan
The ignition switches are not SUPPOSED to come off...
I would bet that unless its exactly an MX-3, the ignition will not line up properly. It will fit on, but won't match up to the hole in the plastic column housing. I've tried a 323 hatchback, and its not the same.
Re: ignition
Posted: April 26th, 2010, 3:31 pm
by blue93
ty
were gonna do some trail and error tomorrow, but if all else fails its $100 ordered in
Re: ignition
Posted: April 26th, 2010, 3:51 pm
by Ryan
No, if all else fails, someone on here has a spare steering column they have the key for and can get for you for much less than $100.
Re: ignition
Posted: April 26th, 2010, 4:04 pm
by SpatialTerror
well are you just talkin bout the ignition switch on the steering wheel lock or the whole assembly.
cuz like its been said the colum isnt supposed to come off. (the steering wheel lock)
but the switch itself can come off.
last year i broke my key off in the ignition. so i wraped a rope around the steering wheel and busted the steering wheel lock.
took of the switch itself cut the wires and put it on switches.
i kinda like it.
cuz if you think about it.
someone trying to steal my car outa the blue. wont be able to start the car by screwdrivering the ignition. and if they bust the colum cover there wont be any wires there to hot wire the car.
Re: ignition
Posted: April 26th, 2010, 4:06 pm
by Ryan
If you grind into the top of the 'rivets' that hold the ignition cylinder to the column, to make them into a flathead screw, you can pull them out. They're not made to come out, thought, but they do.
Re: ignition
Posted: April 27th, 2010, 9:50 am
by blue93
ty for all ur quick responses, we managed to get a 1st gen protege in there with alittle work
