Turn Signal Issues and Gas Issues
Jarek93
Post by Jarek93 »
I replaced my signal relay and the bulbs and none of my turn signals work. The clicking is active when i use the turn-signal, but there is no arrows that appear on the driver-dash.
Also, my gas-gauge constantly says E and has the light on saying that my tank is empty, however it is not and I can drive around for hours to prove that there is gas in it, i basically remember that 20$ fills up my tank and I just go from there usually. However I would like to fix it, as well as fix my turn signals.
Ryan
Re: Turn Signal Issues and Gas Issues
Post by Ryan »
Not sure on the signals, but the float in your tank has a leak in it, and sank. just replace it. any Mx-3, and I would imagine any 323 of similar style.
Jarek93
Post by Jarek93 »
thanks. i just pm'd you cause i saw you were online. will do.
Jarek93
Post by Jarek93 »
Fixed it.
Problem: Bad Hazard Fuse that had the filament still in tact forming a Z like it should, but it was still bad due to something else, my guess is corrosion. [go figure]
