Spring cleaning...hurray!
SteeleMX3
Post by SteeleMX3 »
So, spring is hear and the new sunshine has shown me my disgusting ways of winter :( I NEED to clean her out ASAP and I know I could just get in there with a vacuum and some patience but I thought I might as well get some feedback before hand. Does anyone have a good system for a really efficient interior scrub-down?? I talkin everything from the dash to the floor...and more! :shock:
cheers.
Thought I might make this compilation of ideas into an organized list to help anyone else out who's wondering, I know this really helped me out! Cheers. :2thumbsup:
Exterior:
- “just pressure wash her to rinse, brush down using a soft brush and soap designed for cars, and pressure wash
rinse. Don't forget the engine bay, and the door jambs and the drain channels around the hatch and stuff.” – Ryan
- “For the windows, use a mixture of Rubbing alcohol, a little vinegar, and a tiny bit of detergent.” – Fowljesse
Interior:
- “A chamois just with water, rinsed a lot, on the vinyls. If you're serious, remove simple panels to get at them and the cracks better.
If you're real serious, remove the entire carpet; vacuum the crap out of it. Then get it nice and wet first a pressure washer, and then a carpet cleaner or something. Use carpet shampoo. Same with the seats.
Wait for it to dry, and reassemble. You can also vacuum out the shell while you're at it, maybe scrub it down and coat it, too.
This is a good opportunity to sand blast or soak the gas/hatch popper in some anti-rust formula, paint it, and reinstall.” – Ryan
- “Use a wet vac... That will make the interior mint. For all the plastic pieces I use 303 protectant.” – Hoodzy
- “A Q-tip, and toothbrush are my detailing friends. The seats are easy to take out, so I'd do that first, and then go nuts with a Rug Doctor, or something similar.” – Fowljesse
- “A decent enzyme cleaner will make the world of difference and in bad spots on the carpet, a good quality fabric spray paint can make it look like new too if you have some real bad stains. Also when you do any armor all be sure to spray a cloth and wipe it on instead of spraying the panels, it comes out even and stops any overspray.” – Sleeper6
- “Disassembly is the key to a really clean interior.” – Wytbishop
- “Baby oil is just as good as armor all.” – SuperK
- Meguiar’s or Mother’s “back to black”
1992 Mazda MX3 Precidia GS-KLZE :: Rockin' my world since 2009
viewtopic.php?f=46&t=72989 ---> Workloooogg
Ryan
Re: Spring cleaning...hurray!
Post by Ryan »
Depends how serious you are.
Externally, just pressure wash her to rinse, brush down using a soft brush and soap designed for cars, and pressure wash rinse. Don't forget the engine bay, and the door jambs and the drain channels around the hatch and stuff.
Internally, a shammy just with water, rinsed a lot, on the vinyls. If you're serious, remove simple panels to get at them and the cracks better.
If you're real serious, remove the entire carpet, vacuum the crap out of it. Then get it nice and wet first a pressure washer, and then a carpet cleaner or something. Use carpet shampoo. Same with the seats.
SteeleMX3
Post by SteeleMX3 »
wow, good stuff. Will give this a try, I am for serious about this whole cleaning deal so it's goin down!
thanks Ryan.
Mnemonic
Post by Mnemonic »
here in Atlanta, Georgia I do spring cleaning every morning... I HATE POLLEN!
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Hoodzy
Post by Hoodzy »
Use a wet vac.. that will make the interior mint.
1995 Creek Mica Blue GS
fowljesse
Post by fowljesse »
A Q-tip, and toothbrush are my detailing friends. For the windows, use a mixture of Rubbing alcohol, a little vinegar, and a tiny bit of detergent. The seats are easy to take out, so I'd do that first, and then go nuts with a Rug Doctor, or something similar.
Sleeper6
Post by Sleeper6 »
a decent enzyme cleaner will make the world of difference and in bad spots on the carpet, a good quality fabric spraypaint can make it look like new too if you have some real bad staings. Also when you do any armorall be sure to spray a cloth and wipe it on instead of spraying the panels, it comes out even and stops any overspray.
Post by wytbishop »
Disassembly is the key to a really clean interior...which is why mine is not really clean.
SteeleMX3
Post by SteeleMX3 »
If I wanted to not just polish my dash, interior panels, and other black plastic surfaces, what would you guys recommend? I've heard good reviews about that Mother's "back to black", preferences please :D
also, about that fabric spray paint, it ACTUALLY works???
fowljesse
Post by fowljesse »
I like Mother's, and Maguiar's. I don't like Armor all, because it would evaporate, and leave residue on my windows. Someone said that it doesn't do that anymore, but I haven't investigated.
Sleeper6
Post by Sleeper6 »
Sadly yes, I worked in a detail shop for a bit in pittsburgh and on the really bad stuff, they just sprayed it and put down some good freshener. Ppl never knew the difference, also they even kept black paint for doing the inner fenders too, sounds silly but some of them came out really nice.
SuperK
Post by SuperK »
Baby oil is just as good as armor all... I'm not joking!
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
anjin1982
Post by anjin1982 »
superk i tried the baby oil on my cowl and it didnt last as long as i thought it would...any ideas people on how to maintain a "wet" look for the cowl...baby oil i found is good for seals and painted areas inside the car...
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
Ryan
Post by Ryan »
There was a writeup on here, way back when, for how to make your cowl look like new.
Searching... searching....
Can't find it.
Try painting it!
SuperK
Post by SuperK »
LOL Ryan, it's stickied on the top of the appearance forum. Oh god, you couldn't make that up if you tried.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
Return to “Appearance”
