Hatch Light
Posted: March 28th, 2010, 11:26 pm
by anjin1982
Ok so i cant seem to figure out why i got no voltage @ the hatch light connections. Am i testing it right? I tried going from my meter to each lead and got nothing then one from the meter to strut bolt switch the wires and still nothing... All my other lights work and i checked fuses...
Re: Hatch Light
Posted: March 29th, 2010, 11:58 pm
by Newfie_dan
You can either trace the wiring and see if there is an issue or use a test light, sometimes you do not get the best ground off strut bolts, try using the bolt that holds the rear seat down you should get a better ground off that. If that fails try a voltmeter and measure between the 2 leads for the hatch light. Also remember that the hatch light is switch operated, make sure the switch is in the on position.
Re: Hatch Light
Posted: April 4th, 2010, 6:57 pm
by anjin1982
Ditto the problem was at the harness in the hatch so i spliced those and bam light again!!! THX....i didnt realized there was a switch in the hatch lock itself
Re: Hatch Light
Posted: April 4th, 2010, 10:45 pm
by Ryan
Yup, so when you close the hatch the light goes off
Re: Hatch Light
Posted: April 27th, 2010, 7:31 pm
by anjin1982
sorry for the late delay but its fixed i tracked it down to the connector behind the driver passenger harness which corroded the connections which came from a hole in my wheel well so driving driving in the rain would kick water up and gravity would take it down and imagine my surprise when i removed the rear interior and noticed rust spots and mucky water
![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
Re: Hatch Light
Posted: April 27th, 2010, 10:40 pm
by Newfie_dan
that would certainly do it alright, dont ya just love gruesome discoveries liked that.
