swaybar links
swaybar links
'94 mx3.......... i purchased the zx2 struts. and am tryin to put more weight on the left front and right rear. my question is how much can i lengthin the links ??? will to much bind the suspension ? keep in mind this is for a dirt track setup......thank 4 ur help
- fowljesse
Re: swaybar links
I assume you have spherical adjustable links. I adjusted mine the same way, but more for autocross corner balancing. At first, I made the mistake of adjusting them while the car was on the lift One bolt broke. SO, while the car was on the ground, I put more outgoing tension on the driver's side, until it "felt" like enough. We here in Oregon were talking about renting 4 scales to corner balance our cars. My car handles very neutrally, and predictably. I have actually maintained a 4 wheel "drift" around an onramp, keeping up with an M6.
