Page 1 of 2
audio not working (SOLVED)
Posted: March 14th, 2010, 1:19 am
by mitmaks
so my computer's audio is not working all of sudden. Ive tried installing/uninstalling audio driver. It shows installed but audio still doesn't work. What gives?
Re: audio not working
Posted: March 14th, 2010, 1:37 am
by _-Night-Shade-_
Restart PC? Make sure it's not muted?
Posted: March 14th, 2010, 1:55 am
by RS_OBD'oh_2
can you run the audio test in the bios? That will narrow things down a bit.
Posted: March 14th, 2010, 3:51 am
by PATDIESEL
have you tried another set of speakers to rule out that issue? Also, could just be a blown circuit in the audio out on the motherboard...
Posted: March 14th, 2010, 1:15 pm
by mitmaks
If I go into Sounds and Audio Devices it says "no audio device"
Posted: March 14th, 2010, 5:28 pm
by _-Night-Shade-_
Then it's either a hardware issue or you did something funky with the driver. Try rolling back to the previous driver?
Posted: March 14th, 2010, 9:36 pm
by 2fazed
Did you change any of your updates/drivers? I know my audio won't work without SP3.
Posted: March 14th, 2010, 9:48 pm
by mitmaks
nope, nothing changed. Was working fine, went to garage for an hour or so came back doesn't work.
Posted: March 15th, 2010, 9:28 am
by Evo_Spec
try system restoring back to before this problem happened
Posted: March 15th, 2010, 1:38 pm
by mitmaks
Evo_Spec wrote:try system restoring back to before this problem happened
did that, no luck
Posted: March 15th, 2010, 5:00 pm
by PATDIESEL
good lord, go buy an audio card and install it. They are not expensive and you'd be done by now
lol
Do you know how to install new cards into the computer?
Posted: March 15th, 2010, 5:25 pm
by mitmaks
Of course, why would mine quit all of a sudden. They shouldn't just randomly burn out, maybe Toyota built it.
Posted: March 15th, 2010, 5:29 pm
by ninjajim4
go to control panel -> system -> hardware -> device manager and tell us what it says for sound, video and game controllers. make sure there are no yellow exclamation points or unknown devices. if there are, see if any of them are audio devices
Posted: March 15th, 2010, 6:34 pm
by mitmaks
Thanks guys. Problem solved. Had to uninstall a few things that had exclamation point next to them and rescan for hardware and it fixed itself.
Re: audio not working (SOLVED)
Posted: March 15th, 2010, 6:46 pm
by waspone
Buy yourself a MAC!
