wired in HEI mod... Starts up than stalls
Posted: March 12th, 2010, 11:30 pm
by DiaMagus
anyideas
Re: wired in HEI mod... Starts up than stalls
Posted: March 13th, 2010, 2:00 am
by Ryan
vac leak.
Posted: March 13th, 2010, 4:12 am
by DiaMagus
... It started before the HEI ... Its just not sparking after it initially starts revs up than dies
Posted: March 13th, 2010, 10:12 am
by Ryan
well, to be super specific, the car uses the cam angle sensor (NE1 signal) for startup/cranking/super low RPM conditions, and switches over to G signal (crank signal in disty) for running conditions, but in failure of G signal, it uses the external crank position sensor.
So, check your crank position sensor. clean contacts, and resistance should be between 520 and 540 ohms, IIRC. its in the shop manuals, under B2, IIRC again.
Posted: March 13th, 2010, 11:14 am
by DiaMagus
thanks bro
Posted: March 13th, 2010, 11:10 pm
by Ryan
But the most obvious thing is still a massive intake leak/VAF not plugged in!
Posted: March 14th, 2010, 5:41 pm
by DiaMagus
oh god duh I prolly forgot to hook my intake back up haha ima go check
Posted: March 14th, 2010, 7:13 pm
by DiaMagus
Nothin still wont stay running... Why would it have anything to do with the CSPS if it worked fine before the hei mod :p
Posted: March 14th, 2010, 8:40 pm
by wytbishop
If you have a timing light hook it up and have someone start the car. If the light stops strobing before the engine dies you'll know that it is spark related.
Can you keep it going using the throttle?
Posted: March 15th, 2010, 1:42 pm
by DiaMagus
Nope can't ;p
Posted: March 28th, 2010, 7:03 pm
by slayer322
sounds like vaf, or out of fuel
