Sohc to Dohc Engine Swap
gamenerd90
Post by gamenerd90 »
Hi I have a 1993 sohc base model Mx3. My transmission gave out on me and I recently purchased a 95 Mx3 with the dohc engine. To my knowledge the transmission would be plug and play but was not sure about the engine. Is there any way someone could completely explain what needs to be done in order to swap the dohc with the sohc (or point me in the right direction) as this engine has even less miles on it and is much more powerful thank you in advance for all your help.
Evo_Spec
Re: Sohc to Dohc Engine Swap
Post by Evo_Spec »
here's your directions
search.php" onclick="window.open(this.href);return false;
gamenerd90
look man i just wanted some friendly help not someone who feels like being an a--hole
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
Easy now.
Did that link not work for you?
Don't be so lazy. There are many many quick easy answers here, but you have to be willing to look for it. You would have found the answer sooner than it took you to talk sh!t. Oh, and you forgot to thank EVO for showing you the link to the search function.
SuperK
Post by SuperK »
I think you need to edit your last post, gamernerd. We want to help you but please keep the attitude off the internet.
We want to educate you on forum etiquette... calling someone a a-hole isn't the right way to do so. Please start over. If you can help yourself, reference all the information that you've found, then ask your questions specific to the knowledge you've gained.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
SpatialTerror
Post by SpatialTerror »
well i am not 100% but i think the only real difference in the motors is the heads. so it should bolt right up. and plug and play.
s*** now i have a question. haha i got a 92 4banger manual. its a dohc. now did it come with that motor? or was it swapped?
and whats the specs on that motor. like whp and lbs/torque
i dont know much bout my 4banger cuz it just sits now.
also cuz i got the gsze
SpatialTerror
No one does a SOHC to DOHC swap, it's just not worth while in the effort. One thing I'm curious about is if it'll work because of the difference harness that they use.
If you're car is manual, put in a BP, more power and it's compatible with your OEM harness.
If you're car is automatic, you probably are stick with the SOHC unless you swap to manual or change the engine harness.
mrwhite
Post by mrwhite »
What's the diff between the 1.6 dohc from manual to automatic .
And I used the search option..didn't turn up anything
umcamara
Post by umcamara »
Nd4SpdSe wrote:No one does a SOHC to DOHC swap, it's just not worth while in the effort. One thing I'm curious about is if it'll work because of the difference harness that they use.
His '92 may already have been BP swapped, that may be why it's DOHC. He should look into that.
'98 BMW 328is M-Tech
Feedback Thread
SpatialTerror
that would be freakin sweet if i already have the bp.
how would i know?
and did the dohc motors come in the 92? or just the sohc
SpatialTerror
RS_OBD'oh_2
post a pic and we'll let you know in about 5 seconds
SpatialTerror
SpatialTerror
SpatialTerror
so it is the dohc i know that cuz i pulled the valve cover and for the fact it says 16valve on the valve cover.
but what years came with what motors?
SpatialTerror
umcamara
Post by umcamara »
That's a B6-ME dude. It's the SOHC 1.6 L. There are SOHC engines which use 4 valves per cylinder, as this one does. That's definitely not a BP or the DOHC B6-DE.
Feedback Thread
PilotSmack89
Post by PilotSmack89 »
umcamara wrote:That's a B6-ME dude. It's the SOHC 1.6 L. There are SOHC engines which use 4 valves per cylinder, as this one does. That's definitely not a BP or the DOHC B6-DE.
+1
You got the B6ME SOHC in your car, bud. Mine looks identical. Cept cleaner :P
-Blaze Red 92 MX-3 RS w/ Brembo rotors, Infinity Kappas 62.9i
"MA! THE MEATLOAF!!"
