question
Posted: March 8th, 2010, 9:17 pm
by TheGame86
hi my car is a 1992 mx3 automatic my hold signal started blinking is it a problem? how can i fix it the strange thing is that my speedmeter out of no where stopped working and after that the hold signal started blinking.
Re: question
Posted: March 8th, 2010, 9:26 pm
by PilotSmack89
You definitely put this post in the wrong section. And there is no need to post the same topic twice... please avoid cluttering the forums... much appreciated!
When you say the speedo stopped, you mean it froze at a set speed? Or went back to zero?
Re: question
Posted: March 8th, 2010, 11:41 pm
by TheGame86
no it stopped les than zero and my hold light started blinking and my bad for the post
Re: question
Posted: March 8th, 2010, 11:52 pm
by PilotSmack89
Anyone chime in here, but to my knowledge, the speedo is controlled by the Distributor. For it to go to zero without actually stalling suggests a busted cable somewhere. Also, an intermittently flashing hold light also suggests bad cable connection. Start following wires.
