B & M Pro Edge Shifer
Posted: June 18th, 2001, 3:36 am
by Guest
since this seems like a very popular mod, i was wondering if anyone would like to comment on the easiest way of going about this as well as what is entailed in this (i.e. what someone would need to buy to complete the entire mod). Any help on this would be greatly apreciated.<P><BR>----------------------------------<BR>92 Black GS<BR>----------------------------------
Re: B & M Pro Edge Shifer
Posted: June 18th, 2001, 5:29 am
by cjthor
Hiya<P> This mod is pretty simple. I have the good fortune to have a couple car lifts at work so it was a little easier. The only other thing you need is a shift knob. I went with a Razo carbon fiber. To install you need to pull your lower dash where the radio is. Then underneath remove the bolt off the bottom of the shifter. up top on the shifter base there is a dust boot and a keeper spring that you must remove. Old one slides out...Pro shifter in. Replace keeper, put dash back together and screw the new knob on. It sure does make a difference. Especially when youre "squeezin" a couple more outta the car and tryin to keep the car under a 15. If you need pics I have a coule of underneath the car and of the shifter in the car. Have fun..<P> Jarid Perry<BR> 94 Blaze Red RS<BR> 14.62@99.4mph<BR>
Posted: June 18th, 2001, 6:34 am
by Darbee
hey, <P>I just got my car into the body shop, and putting the B&M short shift in, don't know how it feels, But I heard people saying that it doens't really make a difference, but I drove my friend's 91 miata, i felt that the shift is really short and really tight, very strong, and i like it, but don't know if the B&M feels the same !! <P>
Posted: June 18th, 2001, 9:50 am
by Guest
i've heard things about the bronzoil bushings, is this a worthwhile this to do as well when i change it to the pro edge shifter or what. i'd like to get some good opinions on this one.<P>thnx everyone.<P>Nefarius<BR>--------------------------<BR>92 Black GS<BR>--------------------------
Posted: June 18th, 2001, 11:57 pm
by precidian
I have the B&M shifter installed in my car. The shift throws are alot shorter than stock and when I shift into 5th gear I don't hit the passangers knee.<P>With a short shifter you will have to apply slightly more force to shift but now the shifts are more precise and no missed gears......<P><P>------------------<BR>Tom S. <BR>'94 GS Sparkle Green<P>My MX-3: <A HREF="http://www.mx-3.com/people/ownerdetail.cfm?OwnerID=265" TARGET=_blank>www.mx-3.com/people/ownerdetail.cfm?Own ... R>HomePage: <A HREF="http://members.home.net/tomtsp/" TARGET=_blank>http://members.home.net/tomtsp/</A>
Posted: June 19th, 2001, 1:23 am
by Darbee
I got the B&M in my car now, and it feels really tight and short, I think i need time to get used to it, but it really shorten the time to shift, I think it is a great mod !!
Posted: June 19th, 2001, 10:11 pm
by RayRay
does anyone have pix of the shifter after the install? i'm curious to see how short the shifter is and how short the throws are. thanks. <P>------------------<BR>----------------<BR>'92 GS
Posted: June 27th, 2001, 11:40 pm
by Guest
i just wanted to say i finally got around to putting the pro edge shifter in my car. all i can say is DAMN!!!!. it makes a huge difference. i would recommend this mod to anyone. that annoying problem w/ hitting the passenger's knee is gone, thats nopt that big a deal but still. the shifts are so much easier and faster. so far the only downside that i've noticed (prolly cause its really new) is that when it's in reverse, it is a little hard to get out of gear, but its not a bad thing at all.
