Running rich enough to smoke
Posey24
Post by Posey24 »
So when it did run it ran rich enought to smoke and fail a smog. Could bad timing cause this cuz my tensioner was bad at the time now it's gone any thoughts or things to inpect while the car isn't/can't run
_-Night-Shade-_
Re: Running rich enough to smoke
Post by _-Night-Shade-_ »
Posey24 wrote:Could bad ting cause this
Lots of tingz could cause this yo!
Posey24
Post by Posey24 »
I hate bad tingz lol I ment timing
Post by wytbishop »
Just because the tensioner is bad wouldn’t necessarily mean the timing would be off. The Tensioner only prevents the belt from skipping it only affects the timing a very small amount if it’s really loose. If the belt had skipped the engine wouldn’t run...or it would run so poorly you would know something was wrong.
Extreme richness could be a number of things. A bad injector could be dumping fuel although when they fail they are more likely to deliver less fuel not extra. A sensor (IAT, VAF or coolant temp) could be telling the ECU that the there is more air going in than there really is...or that the air temperature is much colder than it is. Try a different VAF. Try cleaning the TB.
Have you pulled the codes? That should be the first step.
Posey24
Post by Posey24 »
looked up how to pull codes but I may jus be stupid but I don't see anywhere on my gauges where a cel would be. I have a 92 gs could mine not have one
Post by wytbishop »
no...it's there. Put the paperclipp in and turn the key on and you'll see it flashing.
Newfie_dan
Post by Newfie_dan »
he would see a check engine light unless the bulb is burnt out, I have seen that before.
Ryan
Post by Ryan »
Or someone took it out for him :wink:
Black Smoke - Fuel
Blue Smoke - Oil
White Smoke - Coolant
RX8SE3P
Post by RX8SE3P »
Newfie_dan wrote:he would see a check engine light unless the bulb is burnt out, I have seen that before.
Or if you live in Australia or not America, because our MX-3's or 30x as they are called here don't show the check engine light for faults. Same for the MX6s and Probes here too.
1995 Eunos 30x KLZE
Post by wytbishop »
Really??? How do you know if your ECU is angry?
RX8SE3P
Post by RX8SE3P »
wytbishop wrote:Really??? How do you know if your ECU is angry?
We have to use LED to test with all our ECUs.
1995 Eunos 30x KLZE
