Rear disc conversion for an RS
megancathleencarey
Post by megancathleencarey »
Alright, I'm new to this.
Anyone know where to get the parts I need for a rear disc conversion,
and if anyone else has done it?
I've got a '94 RS.
And, a good engine to swap in?
_-Night-Shade-_
Re: Rear disc conversion for an RS
Post by _-Night-Shade-_ »
Been covered many times. You need the GS subframe. Use the search.
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
what he said
http://www.mx-3.com/phpBB3/search.php" onclick="window.open(this.href);return false;
a bit of a waste too
MapaX5
Post by MapaX5 »
megancathleencarey wrote:Alright, I'm new to this.
I've got a '94 RS.
you need the rear sub-frame.
unbolt the brake lines, they are hard metal, not rubber, so this needs to be done first.
unbolt the trailing arms to each of the knucles, then take off the 4 14mm bolts that hold the frame up. drops down very nicely.
despite what others say, i like the looks and the better performance.
you DEFENETLY NEED the proportioning valve, or your fronts will get locked up easily. disc brakes need more pressure than drums.
although someone posted the brake booster was needed, i didn't use it, and have no issues. it's actually better for me as i'm used to having hard brakes.
and a good bleed. lol.
i JUST did this, literally. like 3 weeks ago, and couldn't be happier.
'91 MX-5 with plenty of mods, '94 DOHC MX-3__HP Design muffler, glasspack, custom intake (superk's idea), KYB GR-2 shocks, projector headlights, GS front end, Rear Disc brake conversion, swaybar and tie bar, and lip spoiler, JDM mazdaspeed full-length side skirts,
umcamara
Post by umcamara »
Also the hard brake line to the front driver's side is different since it comes from the proportioning valve on the GS, and the master cylinder on the RS. Might be the other way around, can't remember right now.
'98 BMW 328is M-Tech
Feedback Thread
MapaX5
Post by MapaX5 »
yeah, i didn't replace my PV so i can't say anything about that... and i need to because it's been raining like hell over here and locking front wheels is NOT fun.
Mx3TD
Post by Mx3TD »
Can someone post some pictures of this conversion? i wanna see it (: thank you!
1992 MX3, RS..Sanded... Short shifter,Seat Covers;) , Fart can that sounds decent (:
1992 MX3, GS. Lowered, 18in. chrome rims., Blacked out Tails, Weird Bodykit.
PilotSmack89
Post by PilotSmack89 »
Mx3TD wrote:Can someone post some pictures of this conversion? i wanna see it (: thank you!
Check the worklogs
-Blaze Red 92 MX-3 RS w/ Brembo rotors, Infinity Kappas 62.9i
"MA! THE MEATLOAF!!"
MapaX5
Post by MapaX5 »
i can't exactly post my pics on here for some reason, if you PM me your email addy i will send what i did no problem.
i need think i posted them on myspace or facebook or something, but i don't remember.
_-Night-Shade-_
Look up rekognize's worklog, there are probably more but I can't think of it off the top of my head.
