msd 6a and ms question
have been doing alot of searching, but i havent found specific info that i need. i have a '96 and i need a wiring diagram for wiring in a msd 6a with ms, stock distributer without hei 4 pin. i have a hei but read you can not use it with ms because it does not put out the proper square sine wave. any help with links would be very much appreciated
klze swap, wisco 8.5 comp pistons, pauter rods, act stage 3 clutch, lightened flywheel, UR racing pulley, flex-o-lite oil cooler, 2.5" custom exhaust with high flow cat, B&M short throw shifter, S&R cross drilled rotors, , B&G lowering springs, maxxim 17" gun metal rims, modded nissan injectors, walbro 255 lph fuel pump, areomotive afpr, msd 6a , magasquirt v3, and turboed
